Installing my 10th hard drive - bandwidth compromise
23 Jun 2015
Hi,
I wanted to get 2nd opinion from the OC community.
I have a Z690 system with a 12900k CPU, 3090 GPU, Maximus Z690 (Hero) 64GB of DDR5 RAM and 9 drives.
I have six Samsung SSD 870 QVO 8TB (4 of them in Raid 0), one NVMe Samsung SSD 980 PRO 250GB, one NVMe Samsung SSD 980 PRO 2TB and Corsair NVMe Corsair MP400 8TB. I'm thinking of installing a Seagate FireCuda 530 Series 4TB M.2.
PC Specialist have said if I do this, it'll compromise the performance of my system, their exact words:
then your machine will run out of PCI-e Express lanes and bandwidth. This will then be further subdivided between ALL of the current drives in the machine resulting in them running at a much slower speed.
I have a ROG Hyper M.2 PCI-e Card, that houses all my M.2 drives.
PCS have a tendency to walk a loada' waffle, so looking to get some thoughts and views here before choosing to make the purchase or not.
* Please check PCIe bifurcation table in Chapter 1. ** When ROG Hyper M.2 card is installed on PCIEX16(G5)_1, PCIEX16(G5)_2 will run x8 only and if ROG Hyper M
So no the GPU isn't running maximum performance.
Check the manual and have a read.
Okay, thank you for pointing that out. If it's marginal, then fair enough?
I didn't ask PCS to install it. They did this themselves, so I guess it isn't much of a drop.
Okay, is it worth upgrading to the 13900 CPU and the 4090 GPU?
I've been told the setup I have at the moment is only capable of playing at least half of the games at 4K (Ultra settings) at 60FPS on my ROG Swift PG32UQX.
Others' have said it'd be moronically senseless for me to upgrade the CPU/GPU.
Your thoughts, please?
Can, I point out, just in case, that I'm below a novice when it comes to system knowledge. I'm still learning.
I’m more wondering where you’ve put all these drives - plus if you’re using the Hyper card AND your GPU then you’ve only got 8 lanes for each, and thus can only access 2 of the 4 drives fitted to the card (4 drives need all 16 lanes) but using them in raid may change this.
Photos needed…
