Installing OS from Bootable USB Flash Drive
19 Jun 2004
n/east-the toon
Right my new build will just have a Sata Blu-Ray Rewriter, am l right in thinking that l install OS to a Bootable USB Flash Drive and set the Bios to USB first boot and it should install from there and also install the Sata Drivers for the Rewriter. As my PC’s have always had an IDE CD/DVD-ROM, a little bit unsure about this help appreciated.
Cheers oldphart.
Not that I've tried a Blu-Ray drive myself, but shouldn't it happily be able to read/write DVDs and CDs, be bootable and not require any special drivers?
This information was supplied to me by membe L33 and works perfectly for using a USB drive to install an OS.
Yes. Create an active partition on the USB drive (use diskpart or similar) and simply copy the entire contents of the Win 7 DVD/ISO to the USB drive.
To make an active partition in diskpart...
list disk (make a note of your USB drives number, replace X with it below)
select disk X
clean
create partition primary
select partition 1
active
format fs=fat32 quick
assign
copy over your files for the operating system and then boot away from it.
Taff
