Installing OS on my first SSD, any tips?
smr
smr
6 Mar 2008
Leicestershire
Hi all,
Just abouts to install Win7 on my new SSD which arrived this morn.
Any advice before doing so? I'm sure I read somewhere that someone said SATA mode must be set to AHCI or something? This ? Anything else?
Just set the the mode from IDE to AHCI in the bios, then install like you would any other OS. Trim is enabled automatically and so to are the driver. There's really nothing to do.
You can install the Intel RST drivers if you wish,but the standard drivers are just as good.
http://www.intel.com/p/en_US/support/highlights/chpsts/imsm
thanks, in my bios (GA-X58UD3R mobo) I have
ICH SATA Control Mode
eSATA Ctrl Mode
and a couple of other Ctrl Modes (GSATA 6_7 etc.)
Is it just the ICH SATA Control Mode I need to change to AHCI or shall i change everything where I can to AHCI. Cheers!
edit - nvm I've just set 6-7 which is the SATA 3 port to AHCI and the ICH SATA control mode to AHCI as well, here's hoping for a smooth install!
Unfortunately have lost my USB Pen drive and couldnt be bothered installing off my USB drive as I've have had to take everything off it and then put it back on so installing via CD but hopefully this should be a bit of a faster install than I've tried in the past!
Looks fine to me :)
You can check afterwards:
1. Start> run > type "Regedit" press enter..
2. Open HKEY_LOCAL_MACHINE / SYSTEM / CurrentControlset / Services /msahci
3. Open msahci
4. check the value:
Value 3 = off
Value 0 = on
5. exit "Regedit"
If it's off, then go back to the hive and change the setting to 0 manually as above (use the right click and modify), save and then reboot changing the BIOS entry to AHCI as approriate.
To check TRIM is enbled:
Start> run > type cmd press enter then type
fsutil behavior query disabledeletenotify
press enter
Value 1 = off
Value 0 = on
If AHCI and TRIM are enabled - you're good :)
I just put my ssd in and installed windows on it without doing anything, did i do something wrong?
The most important things to do pre-installation of Windows are:
1) Set the SATA mode in the BIOS to AHCI. This will depend on which controller you're using, Intel SATA 2 or Marvell SATA3. The Marvell SATA 3 is a bit naff but may be better than Intel SATA 2.
2) Disconnect all other SSDs and HDDs .
When i do this i get a blue screen and my pc reboots, its currently set to IDE and the options i get are IDE / RAID / AHSI
Sorry, my post was directed at the OP doing a fresh installation.
Switch back to IDE mode then follow this:
A little guide:
I am receiving a lot of emails from users who bought a SSD drive, installed Windows 7 in IDE mode and then realize they need AHCI mode for faster SSD performance. Once you enable that in the BIOS during Windows 7 boot up, the OS will crash.
The common question is, is there a solve for this ?
To answer that question (and I do this safely with all Intel ICHR9/10 chipsets) there is a way to safely enable AHCI mode. Here we go:
1. Startup "Regedit
3. Open msahci
4. In the right field left click on "start" and go to Modify
5. In the value Data field enter "0" and click "ok"
6. exit "Regedit"
We have not tested this on Vista though.
Once you've done that then restart the PC, go straight back into the BIOS, switch to AHCI mode, save the changes and let the PC restart.
Hopefully you'll be in AHCI mode.
If it doesn't work then just switch back to IDE again and run this:
http://windows7themes.net/download/registry/enable-ahci-windows7.reg
Again once you've done that then restart the PC, go straight back into the BIOS, switch to AHCI mode, save the changes and let the PC restart.
Assuming it works then you might want to install this.
Assuming it works, and you're using an Intel chipset, then you might want to install this.
That fixed it, a lot faster now. Thanks for your help was beginning to wonder if my new purchase was worth it!
