installing sbs2011 simple query help!
17 Jul 2008
OK i have a DVD marked "small business server 2011 premium addon" that installs windows 2009 standard server.
I have a sbs 2011 CD key
the windows that installed from the disk will not accept the CD key
I's assuming i have to "SBS" the windows 2008 standard installation...
and ideas how to make the 2008 server into SBS (bear in mind i did install it from a sbs2011 dvd)
Hi
You should also have another DVD marked Small Business Server 2011. If not, sound like you've only got the Premium Addon part.
There should be 4 Keys IRRC (1 for the SBS part Physical Install, 1 for the SBS VM Install, 1 for the additional Server 2008 the Premium Addon gives and 1 for the SQL Server).
Do you have these?
Rob
Hi
Do you have these?
Rob
no such luck, cannot find a download anywhere... any suggestions where i can get the install from... i see people with 6gb ISO files on youtube but no where to download from
Taken from MSDN:
File Name: en_install_disc_windows_small_business_server_2011_standard_x64_dvd_611535.iso
Languages: English
SHA1: 74764B29F6C5BAFCB680D000F43E138C38A9A414
Google that and you'll find torrents etc (which is perfectly legal as you have the key), just use a hash checker to check the file you downloaded matches the SHA1 above - if it does, it's 100% untouched and original Microsoft.
If you still can't find it leave a note or trust me and I'll download it off MSDN for you to one of our servers and send the link.
Taken from MSDN:
Languages: English
any idea if thats the same as sbs 2011 essentials?
Oops:
File Name: en_server_install_disc_windows_small_business_server_2011_essentials_x64_dvd_664391.iso
Languages: English
SHA1: 58FE96CD15B46107C0030713CB75A18B5FAFEF69
Seems I don't have access to this with my MSDN subscription though. Not sure why, I get every other OS etc. Server 2012 datacentre? No problem. Cheap home server? No, shoo :p.
Oops:
Languages: English
thanks
oh my god, this should not be so hard, i have the server up and running with serial from the link you provided.
now im stuck on sql, the premium add-on dvd jsut has windows on and there is no setup i can see for SQL on the ISO i downloaded or in SB and hints anyone please :)
