Installing Windows XP Problems, possible hardware issue?
26 Jan 2005
Newcastle, UK
Got a neighbours PC here, complaining of the following problem:
http://www.scottjs.net/blue.JPG
After trying the usual, safe mode, last known good configuration and repair windows, I decided to just take the PC home and format it + reinstall.
It formatted fine (full format) and copied the setup files, it then rebooted, then at the point where the setup screen comes on to begin installation, it just stayed black.
I formatted the hard drive again and formatted the MBR. Same thing happens, but instead of the screen staying blank, I now get a new blue screen message saying:
'stop c000021a {fatal system error} the windows logon process system process terminated unexpectedly'.
I'm not sure if the hard drive is a bit iffy or if it is something more serious.
The drive works fine as a slave in my PC.
sounds like the drive is dieing or corrupt have you tryed downloading the drive tools from the manufactures website?
Haven't yet but it's a good idea since it's a western digital I know they have some good tools.
I really hope it is just the hard drive, as the hardware monitor is reading a very toasty 72 degrees C cpu temparature. I'm hoping it is just a wrong reading as it doesn't feel that hot.
