I have read lots of info about AHCI, none of what I read seems conclusive in regard to wheather it should be used or not.
I'll be running the drive on W7 64bit with a fresh install.
Is it worth enabling AHCI? The computer is mainly used for AutoCAD / Music production / Web browsing.
If the drive does not have the latest firmware, do I add the drive under my current W7 install, update the firmware, then format and install from the DVD?
Is this all I need to consider before the install?
Many thanks
Many thanks
