3 Jul 2011 at 19:41 #21 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 Does this one use the same method? Installing Windows XP using a single USB flash drive
3 Jul 2011 at 19:44 #22 Martini1991 Martini1991 Caporegime OP Joined 18 Sep 2009 Posts 30,558 Location Dormanstown. Surveyor said: Does this one use the same method? Installing Windows XP using a single USB flash drive Click to expand... They're dead links.
3 Jul 2011 at 19:54 #23 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 Link to USB_PREP8 and Bootsect on this page. PeToUSB here.
3 Jul 2011 at 19:54 #24 Martini1991 Martini1991 Caporegime OP Joined 18 Sep 2009 Posts 30,558 Location Dormanstown. Is what happens when booting up the second stage .
3 Jul 2011 at 19:55 #25 Martini1991 Martini1991 Caporegime OP Joined 18 Sep 2009 Posts 30,558 Location Dormanstown. Surveyor said: Link to USB_PREP8 on this page. PeToUSB here. Don't know if it's the right one but link to Bootsect.exe in post #3 here. Click to expand... My problem isn't booting...... A bootable USB drive is a bootable USB drive.
3 Jul 2011 at 20:01 #26 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 Martini1991 said: My problem isn't booting...... A bootable USB drive is a bootable USB drive. Click to expand... From what I can see the instructions tell you fow to create a bootable USB and how to get the XP files onto the USB drive. If it doesn't work then I've no idea.
3 Jul 2011 at 20:04 #27 Martini1991 Martini1991 Caporegime OP Joined 18 Sep 2009 Posts 30,558 Location Dormanstown. Surveyor said: From what I can see the instructions tell you fow to create a bootable USB and how to get the XP files onto the USB drive. If it doesn't work then I've no idea. Click to expand... The XP files are on it, and boot, hence why it does the text based part, it's just the GUI part it doesn't.
3 Jul 2011 at 20:17 #28 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 More links. Similar stuff. How to install Windows XP on Eee PC and netbooks, made easy Installing Windows XP on a Netbook Via USB Make sure you're following the steps carefully. It seems to work for other people.
3 Jul 2011 at 20:18 #29 Martini1991 Martini1991 Caporegime OP Joined 18 Sep 2009 Posts 30,558 Location Dormanstown. Believe me, I'm following the steps, may just be the ISO I'm using. I attempted to repair it DOS >.<. Same thing.
3 Jul 2011 at 20:34 #30 Martini1991 Martini1991 Caporegime OP Joined 18 Sep 2009 Posts 30,558 Location Dormanstown. In recovery console I can find and rename the NTFS.sys, so it's there.. >.<
4 Jul 2011 at 21:06 #31 Swordfish Swordfish Soldato Joined 17 Jan 2006 Posts 2,890 Location Dundee I've never had that error when install XP. Looks like you might have a faulty image. I'd try another ISO and use those files.
