Installing XP on a Sata Raptor drive
15 Apr 2006
Soon I will be installing a Windows XP home edition on a 74GB SERIAL ATA RAPTOR hard drive and was wondering what drivers it is I need to put onto a floppy disk before I attempt this?
I have only installed XP successfully on a SATA drive once before and remember it was a bit of a nightmare, so I just want to be prepared before I do again. :D
Motherboard is a 'ASUS® M2N-SLI DELUXE' by the way.
Thank you!
Just make sure that the SATA port you plug the Raptor into is set up as non RAID in the BIOS. If you do that then Windows will recognise it as a normal disk and load onto it quite happily without any extra drivers.
