Installing XP Pro SP2 : SATA
18 Oct 2002
Cambridge, UK
Hi,
Quick dumb question here, if I'm installing XP Pro (SP2) do I still need to provide SATA drivers?
Thanks
HEADRAT
That's what I though, so why is it that when I try an install a fresh version of XP on a freshly formatted HD that after the reboot I get "Error loading operatiting system" :confused:
Will_3rd said:
nope, iirc SATA support was included as standard with SP1
SATA support is not provided per se by any version of XP.
If the SATA controller is configured in Legacy / IDE emulation mode in the BIOS then you can install any OS without drivers. Any other mode or any form of RAID and then you need drivers.
If you've got that far then the install has found the disk and done the initial part of the install. What you're seeing there is a BIOS boot priority issue.
Well the BIOS know to boot from the first SATA device so I'm not sure what else I can do!
I'm not using RAID, just a single SATA1 Raptor.
Solved it, changed the settings on the HD from "AUTO" to "LARGE" it now works, don't you just love computers sometimes :rolleyes: :D
HEADRAT
