Hello,
I'm in the middle of installing an upgrade. I've attached the frame for the Noctua NH-U12F heatsink and put my Intel C2D E6600 on to my motherboard after cleaning and applying AS5 as described in the AS5 instructions (thin, striaght line down the middle).
However, after installing my CPU to my motherboard, here came the tricky bit - putting that large heatsink on my CPU/it's frame while screwing it down. When doing this the heatsink slid slightly in pretty much all directions. I know your meant to twist the heatsink to move the AS5 around a bit, but have I over done it? Do you think I should take the heatsink off, clean it and CPU then reapply the AS5 or should I be ok?
Just for note, I cleaned the CPU using AS Cleaner Stage 2, as the AS Cleaner manual told me.
