# instead of £
Status
Not open for further replies.
6 May 2009
How do you change it so that when you press shift and 3 you get a £ sign instead of #
From Wiki...
On UK Apple Mac keyboards, this is reversed, with the "£" symbol is on the number 3 key, typed using Shift+3, and the number sign ("#") being generated by Option+3. Under Microsoft Windows it can be generated through the Alt keycodes 0163 and 156, and in MS-DOS by Alt-156.
The Compose key sequence is 'L' and '-'.
Go to your control settings > keyboard something or other > and change the layout type to UK, or something like that.
EDIT: Oh, you're on a Mac. In which case, you need to buy a Windows based PC.
From Wiki...
What operating system are you running?
Start - Settings - Control Panel - Regional and Language Options -Languages Tab - Details - Settings Tab
Set 'Default input language' to 'English (UK)' and not 'English (US)'
Under regional and Languafe Options make sure you have the option on the advanced tab, under Language for non-Unicode programs set to English (United Kingdom)
thanks all. user was using email locally instead of citrix for some reason. Thats why it worked when i went onto the citrix session. Just got rid of us keyboard crap and set uk to everything on the local machine
Petrol bombing it will ensure no such problems occur again. :)
you need to press alt+f4
oh, its a mac, i would look it up, but mac sucks
Go and buy a proper PC
Wow you guys are soooooo funny. I am literally splitting my sides with laughter.
Just in case you missed my sarcasm...
Well.. buying a mac is like buying a small island, making it look pretty then marketing it against England with the slogan "at least we don't have all the economic problems!". And it's true, you can go there, relax, paint a good picture... but if you want to actually get anywhere or do anything useful you'll have to go back to England and put up with the messy economy and hectic lifestyle, which only came about because a lot of people use it.
Status
