- 7 Feb 2004
I have some home gym in the garage and the cold has been difficult to motivate me over the winter so I am interested in putting in some insulation to help retain some of the heat. From the few videos I have seen online it looks like I can probably manage it.
The garage is connected to next doors garage. The end has brick, then a gap, then breeze blocks. I assume the same is for the sides.
1. Create a partition wooden frame, double the thickness of the insultation (Not picked yet).
2. Attach a vapor barrier to the back of the frame and underneath all areas touching the floor/walls.
3. put the insulation in the frame
4. Cover the insulation with either plasterboard or wood/board
This is the first job, then repeat for the roof/ceiling
Sound correct? Happy to be educated
Thanks in advance
Thanks in advance
