- 23 Jun 2014
- Cornwall
Hi peeps,
I have concerns with the push/pull CFM balance of the fans in my new system which is an NZXT Phantom USB3.0 Big Tower Case. It has a custom watercooled loop for the CPU and 2 Inno iChill Herculez GTX780 6Gb GPU's with an EVGA G2 Gold 1000w PSU. Also I am thinking the direction of airflow of the rad fans is wrong...
To my knowledge/understanding, the front and two side panel fans should be intakes and the rear and two rad/top fans exhausts and negative pressure is better than positive pressure.
The way it has been done is:
Front Intake 1 x 140mm Spectre Pro 1200RPM 86.73 CFM
Windowed Side panel Intake 2 x 120mm Spectre Pro 1200 RPM 56.22 CFM
Rear 1 x 120mm Spectre Pro exhaust 1200 RPM 56.22 CFM
Top Rad Intake 2 x 120mm Spectre 1000 RPM 43.5 CFM. Fans are mounted on top of the radiator.
The two radiator fans have been fitted as intakes above the rad where I thought/feel they should have been fitted as exhausts below the rad, blowing through it and out? Should I move these two rad fans to below the rad and have them as exhausts?
I know it's only a guide adding up the CFM's but if I were to change the rad fans to exhaust then I would have around 199.17 CFM from intake fans and 143.22 CFM exhaust. Again from my understanding and knowledge negative pressure is better (more exhaust than intake) plus the obvious laws of physics that heat rises tells me that the top fans on the rad should be exhaust. Even with the fans on the rad exhausting heat I would still have more CFM from the intakes by the numbers.
Bear in mind that the two Inno GPU coolers and the exhaust from the bottom mounted EVGA PSU with fan uppermost has not been considered here.
So what is the consensus here? Do I leave the rad fans as intakes or change them to exhausts and do I mount the fans above or below the rad? Secondly is the CFM setup (whichever way the fans are going to work) at it's optimum?
That question out of the way my second problem to be solved:
My case has the 6 Bitfenix red LED fans and I wish to connect the LED's to the switch on the back of the case, the switch only has one 2 pin female connector and no power. The fans are connected to the fan controller switches built into the top of the case but the fans also have a separate jumper loop on each, which can be unplugged, and the supplied LED pos/neg 2 pin cable plugged into the jumper. This then requires a power supply and a connection to the on/off switch so the LED's can be turned on and off separately to the fan. Is there a way for me to connect 6 LED 2 pin cables to power and to the case on/off switch on the back of the Phantom case and how would I go about doing this in a nice neat and tidy way? Some sort of 6 in 1 out plus power type adapter maybe? Where can I source this?
I really want to get the fan situation sorted so I can finally power her up for the first time and make sure everything else is working as it should. The LED issue is something I can do at any time.
Any help would be much appreciated, thank you!
