Work colleague is just speccing together a Laptop from a stone-like company, and under Expansion Slot is listed the above Intel 1gb Turbo Memory... what is this? I thought it might be a USB Memory pen but as an Expansion Slot?
Vista use's USB sticks to speed up the system. Do a search on readyboost. Some laptops have the USB stick built into the laptop as you cannot really go around with a USB stick in the back all the time.
So on ready-build systems like this, why dont they just stick in an extra gig of ram?
"I believe normal ram is a lot faster at the moment? "
Normal ram is better and it costs more. You can never have to much ram and its better to have readyboost with normal ram then it is to only have normal ram.
vista readyboost is only beneficial for machines running vista with less than 1GB of ram. at 1GB, the difference is minimal, and nonexistant with more than a gig.
