Intel 510 and ssd tool box
6 Apr 2009
Liverpool
just went to run the toolbox and it says this tool is not supported on selected drive even though i select the intel 519...it also says in the intel optimizer which is in red about the latest firm ware and all i have the latest firmware on my drive....any one got any ideas why the ssd optimizer says this thanks.
ive just seen the info it uses trim functionality do you think that trim isnt working on my drive.....its in the 6gbs port on the asus p6x58d-e which i think is a marvel chipset.
yes its in AHCI mode i checked that last night....just that my old drive i could run the ssd optimizer ..the only thing im thinking is that although it says trim is enabled it possibly isnt working....as its on a marvell controller not a intel one....is there anyway i can tell if trim is working.
