Intel Chips and Heat / Power Usage
7 Nov 2006
Stockton on Tees
Areet Guys,
Could someone point me to an Intel Dual Core chip that:
- That can handle everything you throw at it (except gaming), 24" Screen at 1900x1200, DvD's, little audio encoding, general surfing, downloading, multi-tasking, multi-media stuff etc.
- Produces little heat (so rpm of fan can be kept low)
- Can OC to circa 3Ghz with little additional power
Any of the new E8xxx series should do you just fine. Alternatively, the E2xxx are much cheaper, and only a little slower and hotter.
Do the Q6600 run cooler than the new E8xxx ?
No because there are four cores on a 65nm manufacturing process vs two cores on a 45nm manufacturing process, however don't get too fixated about the temp thing because its pretty easy to cool an overclocked G0 Quad using a decent heatsink and a quiet 120mm fan.
The only real disadvantage of the G0 Quad appears to be that once overclocked it consumes a great deal of electric, nearly double that of a stock E8500 so . . . .
