Alright can anyone from Ocuk give me a price so i know where to order from?
Didn't know that, is that a new rule?No they dont sell it so cant give you a price
Hows it clocking? Similar to e5200's?Ive had my e5300 for at least a monthj and when i got it, it was only £3 more than the 5200, from ocuk![]()
Is that the R0 stepping? I just ordered at e5300 with R0 stepping...Got it stable at 3.8ghz, its the newer stepping as well. I think i may well do 4ghz but my board may be limitting it ( 680i chipset )
Nice, mine arrived today, just installed it, it runs really cool at stock, getting 50 degrees (I think!) under stress testing with passive cooling! My e4300 used to hit 80degrees at the same speed.Yep R0![]()
I agree is a great chip and runs so much cooler than my e4300 ever did...
So finally after a couple of months, after my first DoA chip got the replacement installed, now for the annnoying bit. It's an E5300 and it is runing on a Gigabyte GA-P35-DQ6 rev 1.0 with BIOS F9. Seems that I can only get 3.2GHz on stock volts and 3.6GHz on 1.35v showing at 1.376v actual. After which temps start getting high and it becomes unstable
I have had the memory set below it's optimal speed to make sure that is not an issue, I am hoping there is something I can do to make it get to 3.8Ghz stable as I wanted. Or should I just accept I got a poor CPU and move on and get something else new?
I will say however I am runninga 480w PSU (Akasa something) with 6 hard drives and 2 optical drives and an 8800GTS 640MB (had a 4770 but only 512MB RAM was too slow on 1920x1200).
Anyways... ideas :?
). Currently have it running at 3.33Ghz with 1.26v. Like i said in my thread, these cpu's are very hit and miss when it comes to overclocking. It will not be your psu at fault as i am only running a 385w Enermax Pro 80+ with mine. The rest of the rig is a Gigabyte P35 DS3R, 2x1Gb Patriot extreme PC2 5300, ATI HD3850Pro, Creative Audigy 2ZS, Seagate 7200.10 320Gb sata hdd, sata dvdrw, Zalman ZM-MFC2 multifunction controller and 5x fans. Total system power draw is a max of 201w at the wall while running Orthos and Fur stability test at the same time. Normal load is 112-128w load, 81w idle.
