Intel G2 SSD 80GB comparison help
Caporegime
24 Dec 2005
Autonomy
This is in my laptop as boot
This is in my PC as boot
Both identical drives G2 intel 80GB
why is the laptop so slow?
IN pc the ssd is the only drive in the laptop I have a second 250GB mechanical drive could this be something to do with the speed?
What mode is the SSD in the laptop running in, AHCI or IDE?
I set the sata port to AHCI in bios before I installed win 7
I have a feeling its the bus now...Thought it was sata 2
My main rig with the same drive is sata 2 on X58 chipset
EDIT: wish I'd have benched my 7200 120GB mechanical drive before I swapped it over
Here is a benchmark from my 3 year ol Dell 15R using a 160GB G2. I think the 160GB is generally ~10% faster than the 80GB version, but it should be a reasonable comparison of laptop performance.
How old is your 1700, and have you installed intel SSD Toolbox and ran it's optimiser and TRIM functions?
This drive benchmarks about 20% slower than it did within my desktop. Laptops are just slower.
SiSoftware Sandra
Computer
Manufacturer : Dell
Model : Vostro 1700
Serial Number : 79K****
Chassis
Manufacturer : Dell
Type : Portable
Can be locked : No
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Security State : External Interface Locked-out
Mainboard
Manufacturer : Dell
Multi-Processor (MP) Support : No
Model : 0HX766
Serial Number : .79KK23J.CN4************
On-board Devices
NVIDIA NB8P-GS : Video Adapter (Enabled)
Sigmatel 9205 : Sound Adapter (Enabled)
Chipset
Model : Dell Mobile PM965/GM965/GL960 Express Processor to DRAM Controller
OEM Device Name : Intel Mobile PM965/GM965/GL960 Express Processor to DRAM Controller
Revision : A13
Bus : Intel AGTL+
Front Side Bus Speed : 4x 199MHz (796MHz)
Maximum FSB Speed : 4x 200MHz (800MHz)
Width : 64-bit
I/O Queue Depth : 12 request(s)
Maximum Bus Bandwidth : 6.22GB/s
Maximum Power : 8.000W
Chipset 1 Hub Interface
Type : DMI (Direct Media Interface)
Version : 1.00
No. Ports : 4
In/Out Width : 4-bit / 4-bit
Duplex : Yes
Multiplier : 3x
Speed : 100MHz
Logical/Chipset Memory Banks
Bank 0 : 1GB DDR2 SO-DIMM 5-5-5-15 3-20-5-3 1T
Bank 1 : 1GB DDR2 SO-DIMM 5-5-5-15 3-20-5-3 1T
Bank 4 : 1GB DDR2 SO-DIMM 5-5-5-15 3-20-5-3 1T
Bank 5 : 1GB DDR2 SO-DIMM 5-5-5-15 3-20-5-3 1T
Maximum Installable Memory : 8GB
Supported Memory Types : DDR2 SO-DIMM
Channels : 2
Memory Bus Speed : 2x 332MHz (664MHz)
Maximum Memory Speed : 2x 333MHz (666MHz)
Multiplier : 10/6x
Width : 64-bit
FMAX - Fast Memory Access Support : No
Refresh Rate : 8µs
Power Save Mode : No
Fixed Hole Present : No
Maximum Memory Bus Bandwidth : 10.38GB/s
APIC 1
Version : 2.00
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module
Manufacturer : Samsung
Model : M4 70T5663QZ3-CE6
Serial Number : 7459****
Type : 2GB DDR2 SO-DIMM
Technology : 16x(128Mx8)
Speed : PC2-5300U DDR2-666
Standard Timings : 5-5-5-15 3-20-5-3
Version : 1.02
Date of Manufacture : 22 April 2008
Memory DC Line : 1.800V
Timing @ 333MHz : 5-5-5-15 3-20-5-3
Timing @ 267MHz : 4-4-4-12 2-16-4-2
Timing @ 200MHz : 3-3-3-9 2-12-3-2
Memory Module
Manufacturer : Kingston
Model : 9905295-052A00LF
Serial Number : 58CC****
Version : 1.02
Date of Manufacture : 15 January 2009
Sensor
Model : Sanyo DELL UW2807 BAT
Mainboard Specific Support : No
Sensor
Model : Intel Core CPU [P1, C2]
Version : 23.06
Sensor
Model : Intel 965M IMC
Version : 0.12
Temperature Sensor(s)
CPU Temperature : 52.00°C
MCH/Memory/Board Temperature 2 : 53.00°C
Voltage Sensor(s)
CPU DC Line : 1.050V
Battery DC Line : 12.143V
Capacity Sensor(s)
UPS/Battery Capacity : 86.58Wh
System Bus(es) on Hub 1
Version : 2.30
System Bus 0 : PCI
System Bus 1 : PCIe 1.00 x16 2.5Gbps
System Bus 3 : PCI66
System Bus 11 : PCIe 1.00 x1 2.5Gbps
System Bus 12 : PCIe 1.00 x1 2.5Gbps
System Bus 13 : PCIe 1.00 x1 2.5Gbps
LPC Hub Controller 1
Model : Dell ICH8M-E (ICH8) LPC Interface Controller
OEM Device Name : Intel ICH8M-E (ICH8) LPC Interface Controller
Revision : A3
ACPI Power Management Enabled : Yes
Advanced TCO Mode Support : Yes
Advanced TCO Mode Enabled : No
High Precision Timer Enabled : Yes
No. Precision Timers : 3
System Timer : 14.32MHz
Delayed Transaction Enabled : Yes
LPC Legacy Controller 1
Type : SMSC ECE5021-NU
Version : 0.01
No. Enabled Devices : 5 Unit(s)
Disk Controller
Model : Dell 82801H (ICH8) Ultra ATA Storage Controllers
OEM Device Name : Intel 82801H (ICH8) Ultra ATA Storage Controllers
Interface : ATA
Revision : A3
Maximum UDMA Mode : UltraDMA-5 / ATA100
Mobile : Yes
Channels : 2
In Use Channels : 1, 50%
Port : UltraDMA-2 / ATA33
Disk Controller
Model : Dell Mobile SATA AHCI Controller
OEM Device Name : Intel Mobile SATA AHCI Controller
Interface : SATA
Revision : A3
Specification : 1.10
Maximum SATA Mode : G2 / SATA300
Channels : 2
In Use Channels : 2, 100%
Port : G1 / SATA150
Port : G1 / SATA150
Disk Controller
Model : Dell SD Bus Host Adapter
OEM Device Name : Ricoh SD Bus Host Adapter
Interface : SDA
Revision : C3
Channels : 1
Audio Device
Model : Dell 82801H (ICH8) HD Audio Controller
OEM Device Name : Intel 82801H (ICH8) HD Audio Controller
Revision : A3
Type : HD (High-Definition) Audio
Version : 1.00
No. In / Out / Bi-Directional Streams : 4 / 4 / 0
No. Serial Data Streams : 1
Audio Codec
Revision : A5
Version : 1.00
Audio Channels : 6
Audio Codec
Revision : A1
Version : 1.00
USB Controller 1
Model : Dell 82801H (ICH8) USB UHCI #4
OEM Device Name : Intel 82801H (ICH8) USB UHCI #4
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Model : Dell 82801H (ICH8) USB UHCI #5
OEM Device Name : Intel 82801H (ICH8) USB UHCI #5
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Model : Dell 82801H (ICH8) USB2 EHCI #2
OEM Device Name : Intel 82801H (ICH8) USB2 EHCI #2
Revision : A3
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 4
Companion Controllers : 2
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 64-bit
USB Controller 4
Model : Dell 82801H (ICH8) USB UHCI #1
OEM Device Name : Intel 82801H (ICH8) USB UHCI #1
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Model : Dell 82801H (ICH8) USB UHCI #2
OEM Device Name : Intel 82801H (ICH8) USB UHCI #2
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 6
Model : Dell 82801H (ICH8) USB UHCI #3
OEM Device Name : Intel 82801H (ICH8) USB UHCI #3
Revision : A3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 7
Model : Dell 82801H (ICH8) USB2 EHCI #1
OEM Device Name : Intel 82801H (ICH8) USB2 EHCI #1
Revision : A3
Version : 2.00
Interface : EHCI
Channels : 6
Companion Controllers : 3
FireWire/1394 Controller 1
Model : Dell R5C832 IEEE-1394 Controller
OEM Device Name : Ricoh R5C832 IEEE-1394 Controller
Revision : A6
Version : 1.10
Interface : OHCI
Speed : 400MHz
SMBus/i2c Controller 1
Model : Intel ICH SMBus
Version : 0.02
Specification : 2.00
Advanced TCO Mode Enabled : Yes
Slave Device Enabled : Yes
PEC Support : Yes
Speed : 100kHz
Port Connector(s)
USB : USB / USB
MONITOR : Video / DB-15 pin female
FireWire : FireWire/1394
Modem : Modem / RJ-11
Ethernet : Network / RJ-45
Performance Enhancing Tips
Warning 2513 : TPM not detected. Some security features are unavailable.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
According to the Sandra information the maximum SATA mode is SATA 300 (3Gbps) but the two drives in use are operating as SATA 150 (1.5Gbs).
I didn't think that they would share bandwidth but if it's possible you could remove the HDD and see what happens.
Think Ill try that only a 2 min job....TBH I don't need the 250GB second drive really if it improves boot and app launches...
will report back with my findings...:)
