Intel g3258 turns on but when it resets blank screen
Permabanned
22 Sep 2003
Hi any help please
computer turns on fine.
When installing windows when it restarts just blank screen.
When i power off then on works but again when reset just blank screen
any help please
try latest bios if your not already
reset might not be working correctly atm,but aslong as you power down and powerup and it comes on I wouldn't worry
probably a bios bug
up dated bios still the same if you reset will not come on if you keep power button pressed it go off then will come on again normal but no go with reset thinking faulty board?
