I was wonder if i can have some help over clocking my system at stable point 4.4ghz or 4.5ghz the following specs i have are
1000 watt psu
32gb ram
Gtx 970 4gb ddr5
Mother bored, gigabyte x79-u4 socket LGA 2011
Cpu, Core i7 4930k
Cooler, be quiet! DARK ROCK 3 SilentWings CPU Cooler 190W TDP
Thank you so much.
1000 watt psu
32gb ram
Gtx 970 4gb ddr5
Cpu, Core i7 4930k
Thank you so much.
Delidding as darket suggested is the process of removing the metal heat spreader from the top of the CPU and replacing the thermal paste between the heat spreader and the CPU die. Don't confuse the heatspreader with the heatsink, it's simply the square metal section that caps the CPU. On all xxx-E CPUs (including Ivy bridge) there is no thermal paste, the heatspreader is soldered to the CPU die resulting in better thermal transfer. Intel used to do this for all their CPUs, but cheaped out over the last couple of years on all but their high end platform.
