Intel manipulates stock levels to gouge Skylake
22 Aug 2008
http://fudzilla.net/news/processors/38852-intel-slowed-pc-sales-to-increase-skylake-s-price
A recent study shows that the slump in PC sales in the first half was deliberately made to help Skylake sell better since August. Initially analysts believed that sales of the Skylake are hindered by existing stocks of previous Haswells, but it turns out this was untrue.
Tech Trader Daily has found that Intel significantly reduced shipments of its central processing units in the first half of the year, to leave PC maker inventories drained and empty.
Intel is making piles from this. PC makers mainly build their systems on Skylakes and since the supply is low the price is high. Intel does not have to discount to shift the technology, the suppliers have to buy it at any price. Particularly as Intel's only real x86 market, AMD, is having a bit of a snooze.
Diabolical. :mad:
dont see the problem. you would have to be mad to buy the 6700K anyway. i will wait for all the locked cpu's and all the z170 motherboards to come out before deciding to buy them anyway. its like buying a game on day 1, you should expect it to be broken and buggy and be half price on steam two weeks after you bought it!
Availability of the i7 is pretty scant as well, so there tactic has worked as it must be selling like hot cakes.
Business is Business.
Everyone should be buying a 5820K system now instead of mainstream anyway, I'd only entertain Skylake if I wanted SFF or to use the iGPU.
That's like saying everyone should buy a 4 wheel drive.......
As always when it comes to PC components, it completely depends on what your going to use it for.
Yeah, I'm not convinced developers (gaming) will program for multicore any better with in the next few years. I prefer Skylake for stronger single core performance.
What, you expect them to produce millions of CPUs that they are going to market as last gen..?
So a company reduces the number of shipments of a product it is about to replace with a newer product.
And this is news.
Yeap, no developer is going to spend time developing code for 6 core CPU's, when the mainstream have dual cores and quad cores at the maximum. It would be spending time for the 1% that own a 6 core.
There's games out now that don't even run on dual cores. Like it or not we're now in a world where 4 is the minimum. Anyone teaching parallel programming is going to recognise that and it won't take long for the software world to baseline on it.
For what? pretty much anything AAA DX11 uses 6 cores and more.
If your talking about Draw Calls its because they have no choice, DX12 will use 6 and its pretty much native.
No games provide any meaningful performance increase from using a hex or octa core at the moment.
A faster clocked/IPC quad core provides more FPS 9 times out of 10, for those using 1-2 GPU's.
Let's see what CPU's a DX12 game prefers, shall we?
I'll await your damage control rant about how this game doesn't count...
Do people buy K processors to run them at stock?
I remember people putting forward all the same arguments for dual core over getting a Q6600, but I also remember my Q lasting about 2 years longer than all the dual cores people had bought at the time
it does depend on whether you want dual card and how long you want to keep the system for... as a 6700k is the same price as a 5820k it makes the 6700k look like a poor choice, if you are doing it to save money over X99 then it needs to be at least a 6600k or below to save anything and then you are putting a time limit as well as foregoing the multi card option for later on down the line
if you're building to a budget then that is an entirely different conversation to "I have £300 to spend on a CPU what shall I get"
The 6700k can support dual GPU just as well as the 5820k. Remember the 5820k cannot run two GPU's with x16 x16 bandwidth - neither can the 6700k - so they are BOTH in the same boat there. Both run X8 X8 lanes for two GPU's.
The 6700k is cheaper than the 5820k on average, of course not at every retailer.
And of course, some buy -K CPU's to run at stock, as they have the highest stock clockspeeds generally. Skylake overclocks quite well - most are able to get 4.6-4.7 on air - which cannot be said for the 5820k.
For someone who is just gaming on 1-2 GPU's, Skylake is superior IMO. For those using their pc for gaming as well as content creation, rendering video, streaming, then a 6 core becomes the best option.
I have an i7 3570K which I do run at stock, mainly because I'm too lazy to play around with the overclock settings...
Yep, this is what attracted me to the K of my CPU, that plus the higher resale value and the "option" to overclock should I want to.
