Intel® Core™2 - Max Temps?
11 Sep 2003
London
Hi,
what is the general thinking on how hot these processors can run? I had a look on the INTEL website but any documentation I can find is written in gooble-dee-gook that I can't understand.
I am testing a CPU at the moment but it appears to be running very hot under 'full' Orthos load . . .
Have anyone got any linkage to somewhere that explains the upper limits of these chips please, also I'm after a tool that shows if the CPU is throttling?
I'm not sure if this reading above is correct or if I have made a hash of installing my heatsink but the machine is running fine, although I am aware that at some point it should begin throttling and beyond that the machine may close down, but at what temp does this happen?
thanks in advance :)
85 is the max Tjunct temperature, 75 is rather hot, but not 'deadly'. But it doesnt leave you much 'spare' for a really hot day.
I always try to keep my max temps at 65 or lower.
What is your vcore set to? What kind of hsf are you running?
75c seems quite hot for only 3.2ghz and 2mb cache
Its a 1mb cache chip and doesn't need a whole new thread about how hot its getting..
The 1mb chips have a tjunction of 100c :D , same as Quads !!
Not the 85c of the C2D Conroe/Allendales.
Chris Beard said:
Tat will show throttling - frequencies will go down.
Thanks, I was also keeping an eye on CPU-z watching for it to lower the multi but nothing so far?
Thats right, sadly I have no idea what tjunction means? I'm not sure that has anything to do with the max specified operating limit specified by INTEL?
Does nobody know anything about this subject then?
Hasn't INTEL got any information on this written in layspeak?
Cmon guys its a perfectly straight forward set of questions? one of you brain boxes knows I'm sure? :)
  • What is the safe 'max' temperature the Core 2 Duo is specified to run at?
  • At what temperature is the chip 'programmed' to throttle?
  • What temperature does the system shut down to avoid damage?
Just having a look through the datasheets:-
QX6800, max , max working 54.8 (measured center top of CPU), storage 85C (ie processor not running).
E6xxx/E4xxx, max working 61.4, and presumably storage 85C
So somewhere in between those two values in both cases. Intel are quite specific exceeding 85C will increase the risk of failure or reduce the lifespan.
Jokester
Edit: I've heard the figure 82C for throttling but I've never seen anything to back it up.
Damn do you have a degree in thermal engineering then? it made no sense to me whatsoever :confused: :o
Max Working is 61.4°C, what does that mean? also I don't understand what 'storage' means in relation to this?
Yes I have 'heard' a lot of stuff over the years too, its like a web chinese whispers, someone say this, someone else says that?
But what is the truth?
I can look up the specifications on any hard-drive and clearly read in plain english what the safe 'operating' temperature is . . . if I go below or above this limit I would expect to have problems, but when it comes to the processor it all becomes a bit 'mysterious'.
Thanks for your time in cracking this Jokester
Storage temperature is basically the temperature you shouldn't exceed with the processor not in use to ensure that it doesn't get damaged or degrade. Exceeding the temperature (as measure by TAT/coretemp when in use) will according to Intel cause degradation of the CPU and shorten it's lifespan from however many number of years (in excess of 10 years anyway) to something less (probably still in excess of 10years). With throttling/shutdown it should in theory be impossible to exceed this.
Max working temperature is slightly different as Intel specify it as the temperature on the surface of the IHS in the middle. There's no practical way to measure this. The internal diodes will read higher than this, but how much higher is a bit harder to quantify.
So the actual max safe working temperature is somewhere between the 60 and the 85C when measured using the internal diodes.
The solder that glues on the IHS is supposed to melt somewhere between 85 and 100C as well.
Jokester
Huh? that makes no sense?
So INTEL are saying that its not a good idea to put your CPU into an oven when not in use? :confused: :D
Indeed it is?
Did you read this thread before?
Are you thinking what I'm thinking? :)
:p There's a certain degree of truth to that, as some people place them in the oven to melt the solder off to remove the IHS and is presumably the reason why it's 85C as if this temperature is exceed the solder will melt (can't remember the exact figure but it's less than 100C). There could be certain instances, especially in hot sunny countries where you could possible exceed that figure when the CPUs are in containers left out in the sun. For example, as part of my job, for desert installations it's not unheard of to provide sunshades for instrumentation located in the sun to prevent them overheating (though there is the added hazard that hot surfaces >60C can be an ignition source during gas releases :eek: )
Big.Wayne said:
Indeed it is?
That's a new one on me, good read though and a lot more detailed information in there.
Jokester
Its because the terminology is common to all IC devices, you're catching a glimpse of a whole industry. Primarily, its gives the information designers need to create cooling solutions. The most important one (other than TDP) is the Tc or case temp. Its limit is Tcmax or tcasemax or max working. First thing to know is a "case" is the package, the encapsulation of the device, the body. Intels Tcmax is measured at the external centre of the IHS, the sensor read by the motherboard approximates this value, sort of. The "junction" is the silicon, the core or die. The die temperature is Tj, with a limit Tjmax, Tjunctionmax. Some of the Intel papers specify Tj, some don't. Last time I looked dual core was 85C and quads 100C. The cpu is supposed to throttle near Tjmax, they call it TCC (thermal control circuit) activation, assuming its not disabled. The main worry is if case temps should reached 80C, mainly because the Indium alloy solder starts to melt around that figure.
If you look over the XS threads on the subject you'll see I had a few questions on values for early versions of Coretemp, ver 0.95 is correct afaik. But basically the program reads Hex for an assumed Tjunction and DTS values directly from MSR's, registers on the CPU. DTS (digital thermal sensor) is the 'on' die sensors, not at the hottest points, but that doesn't matter. The Tjunction value is a generic value for the processor type. The DTS creates a value and is calculated thus:
Core Temperature = Tjunction - DTS
So if Tjunction = 85 and the DTS reads 50
Core Temperature = 85 - 50 = 35C
http://www.hardforum.com/showthread.php?t=1192840
http://www.relex.com/resources/art/art_heatsinks.asp
http://download.intel.com/design/processor/designex/31559402.pdf
Take a look through the links. The Intel docs, section 4.2 refers to two signals, THERMTRIP# which can't be switched off or ignored and is likely set to or above Tjmax, supposedly stops any real damage and shuts down. The other is the throttling PROCHOT# value, which can be disabled. Part of the TCC with (its been a while so read it yourself) two functions TM1 & TM2. Basically two types of throttle. Anyway, when the DTS (-ve) tends towards zero the TCC trip limit activates the throttle.
I can't be asked to read the sheets again, but the trip point for the TCC is going to be a bit below Tjmax, which is pointless if you've turned it off anyway. If deactivated it will run higher until it shuts itself down. Best not to go too high just in case Tc gets near 80C and the solder melts.
One of the fundamental problems with thinking you know exact temperature figures for these chips is the DTS does not report absolute values. Only the difference from the preset throttling point, which of course they neglect to tell you where it is for each chip. Albeit very accurate for changes (delta) at higher throttling temperatures, trouble is programs like TAT etc, have to assume a temperature to subtract the DTS from, if that's the wrong one then so is the absolute value.
In the end, the only value Intel expects you to care about (by you I mean users, Engineers etc) are the case temps, Tc. Via the thermal diode, uncalibrated and prone to bios offsets. The throttling is all handled by the chip, along with factory preset thermal trip points. The DTS registers weren't meant to be accessed directly. Due to them giving no indication of the TCC value, then using Tjmax is I suppose a reasonable guess point. Assuming its being read correctly, be warned.
Some speculation for you. You could monitor TAT for thermal activation to determine the TCC, then calibrate offsets in Speedfan to give an absolute value, something like 3C from Tjmax would be my guess. Or and this is what I recommend, recalibrate your thinking. It doesn't matter what the core temp is as long as its stable and reasonably lower than the throttling point to avoid long term damage. Because it's 100% accurate close to the throttling point, learn to read the direct DTS temperature as a count down. Overclocked, at some point for each chip as the DTS decreases the chip will become unstable. Personally I'd find that point (within a range) and add 10C (your choice) as a safety margin. Say it has problems at DTS=13 (weakest core), then stay above 23. On my dual core that would read as 85-23=62C, remember as I said 62C is not a "real" figure in either Coretemp or TAT. Anyone that's says there is a "norm" for each model of chip doesn't understand how it works.
"The Coolest" has added this feature to the latest 0.95 Coretemp.
Btw, even that is slightly wrong, its the delta to TCC activation.
Some further reading on throttling and accuracy.
http://www.xtremesystems.org/forums/showthread.php?t=131008
http://www.xtremesystems.org/forums/showthread.php?t=136804
http://www.intel.com/design/processor/manuals/253668.pdf
http://www.xtremesystems.org/forums/showthread.php?t=154909
For reference: I've posted this derivation before, it get used a lot but no one ever gives the proofs. Its a simplification as I've only considered dynamic power and ignored static wattage. Nor does it consider frequency domains. Static basically means the leakage, the power used at stock voltage with no load. In reality its superimposed and increases with the frequency/voltage curves. But it works well enough in this application.
A commonly used expression is for semiconductor power P, P=kLV²F
Where:
L = Load (from software)
V = Core voltage
F = Chip frequency
k = Empirical constant for the chip.
Pd = Total cpu power
TDP = Thermal Design Power
Therefore delta P, i.e. change in power. The constants cancel.
Pd = TDP x (F2/F1) x (V2/V1)²
Or a little easier to understand
OCed Watts = TDP x (OCed Mhz / Default Mhz) x (OCed Vcore / Default Vcore)²
online version
For temps
TR = RCS + RSA = (Tc - Ta)/Pd
Where:
TR = Total Thermal Resistance
Tc = Tcase, cpu case temperature
Ta = Chassis ambient temperature
Pd = Total cpu power dissipation
RCS = Thermal resistance, case-to-sink
RSA = Thermal resistance, sink-to-ambient
Therefore:
Tc = (TR x Pd) + Ta
Intel version
I'll add an example for those interested is back to basics thermal resistance.
Arctic Silver Thermal Resistance:
0.0045°C-in²/Watt (0.001 inch layer)
Assumed 1in²/ contact area on IHS.
Tuniq Tower 120 Thermal Resistance:
0.16-0.21 C/W (2000 - 1000 RPM)
Using (Intel version):
TR = 0.16 + 0.0045 = 0.1645 C/W (Tuniq at 2000RPm with AS5)
Ta = 25C (thermometer inside case)
Pd = 65W (stock settings as Intel TDP ref, 2.4GHz 1.325v, they all say 65W which they can't be, but that's all there is to go on)
0.1645 = (Tc - 25)/65 Therefore Tc = 35.7C
An independent way of estimating the temperature the HSF is actually seeing and proves close to the speedfan/ProbeII values of 34C. If the cpu were at 44C, then at stock speeds and voltages the power dissipation would be Pd = 115W, way more than the stock 65w max thermal design profile.
Going to the other extreme [email protected]
Pd = 65*(3600/2400)*(1.5/1.325)² = 125W
Therefore Tc = 45.5C
Again very close to the speedfan/ProbeII 46C!!!
Thanks fornowagain & Jokester,
I appreciate you taking this time to explain this, hopefully some other people will have learnt a bit more on the subject also.
Thanks fornowagain it's much clearer now, no wonder core temp 0.94 and 0.95 reports different figures because they assume different Tjunction (85C in 0.94 & 100C in 0.95), but the DTS is the same for both versions if I understood it correctly.
Just a summary of some of the more useful bits I've come across to design a custom water loop.
Follow these steps.
  • Work out the system flow rate from the components, use the spreadsheet below.
  • Work out the heat load, I've included a formula and link for cpu power.
    Graphics cards tend to follow the number of PCI-e connectors, no connectors <75W, one connector <150W. Look up the TDP is easiest way.
  • From that work out size of the radiator and the best fans for the job, see the Thermochill and fan slides below.
  • Once the components are chosen its fairly straight forward to estimate the expected temperatures within reason, examples below.
Flow rate
http://www.xtremesystems.org/forums/showthread.php?t=151627
http://www.martinsliquidlab.com/img/MartinsWaterCoolingFlowRateEstimatorv2_5.zip
My loop PA120.3 + Fuzion etc > 2.0 GPM
Heat load.
http://newstuff.orcon.net.nz/wCalc.html
For a M0 QX9650, VID=1.03 @ 4GHz vcore=1.36v
OCed Watts = 95 x (4000/3000) x (1.36/1.03)² = 220W
AS5, TIM
http://www.arcticsilver.com/as5.htm 0.0045 Cin²/W Assuming an 1" square contact on IHS
High pressure fans for rads.
http://www.xtremesystems.org/forums/showthread.php?t=170224
Radiator
PA120.3
http://www.thermochill.com/PATesting/#PA1203
For a flow rate of 2GPM the thermal resistance is 0.017 C/W for high pressure fans.
Assuming medium to high pressure fans. Then 150W per 120mm section is a reasonable loading for a PA series radiator to keep below a 10C delta.
Fuzion
http://www.xtremesystems.org/forums/showpost.php?p=1944520&postcount=304
Assuming an average thermal resistance of 0.057 C/W making allowance for quad nozzle etc.
Final CPU case (not core) temperature.
Ambient + system load (inc pump) x radiator C/W + CPU Load x (block C/W + TIM C/W)
22 + 0.017*(220+18) + 220*(0.057 + 0.0045) = 22 + 4 + 13.5 = 39.5C
Add between 10C to 15C for coretemps, 12C for mine.
So 51.5C
Or for lower speeds and temps, -3 ambient, 3200GHz 1.2V
-3 + 0.017*(137+18) + 137*(0.057 + 0.0045) = -3 + 2.6 + 8.4 = 8C
You also hear talk of temps in the loop and where to place the rads etc, I'll add this to show how a high flow rate system behaves.
For a high mass flow rate, forced convection systems like WC rigs. Temps need not have significantly deltas from inlet to outlet. Starting from the most basic equation for specific heat transfer.
dQ/dt = cM (T2-T1)
where
Q is heat entering the coolant, once equilibrium is reached its the heat leaving the radiator.
M is mass flow rate (density x velocity x area) for a pipe
c specific heat capacity
T, delta T, difference in temperatures from inlet to outlet
Or basically the heat transfer is directly proportional to mass flow rate (or velocity for constant area & density). So if you increase the flow rate you increase the heat transfer. Now if you assume the cpu is dumping a constant heat load Q, then increasing the mass flow rate decreases the water deltaT.
A typical computer WC rig with a flow of 2GPM & 7/16" bore. The water moves at 1.3m/s. A 250W heat load.
Water at 22C has a density of 997 kg/m3 giving a mass flow rate of 0.126 kg/s, specific heat capacity for water is 4186 J/(Kg°C)
250 = 4186 x 0.126 x dT
Therefore dT = 0.5°C
So a radiator capable of dissipating 250W will have a half degree difference from inlet to outlet with typical high flow rates. The calculation can be done for any block.
Big.Wayne said:
Hi,
75oC!!!!
Holy smokes
Im running the same speed of 3.2ghz and im reaching 55oC max under full load
