Intel SRT vs SanDisk ReadyCache - advice please
11 Oct 2010
Iam toying with the Idea of using SRT SSD Caching tech on my new build Iam planning.
has anyone used it or got any opinions on it?
- can I use ANY SSD for this purpose?
I see SanDisk sell ReadyCache drives...are these meant to be used with SRT or can they run on any computer/board/OS with the software supplied? if so what are they like? could I buy a cheaper board without SRT and use SanDisk readyCache drives & software instead?
thanks again
readycache drives are for all motherboards that dont support native caching
if your mb already supports it the any ssd can be used for caching
currently z67/z77 x79,i dont think p67 supports it
ive used it on my z68 and it works very well,i just used a normal ssd,it can only use upto 64gb
As wazza said, you can only use up to 64Gb for caching. If you have space left over you can partition it like a normal drive.
