Intel suck lollipops
4 Aug 2005
Amazing, my new Haswell setup is next to worthless to me. In their wisdom intel removed all virtualisation making WP8 dev impossible using the phone emulator. Probably to push sales of ivy-e etc. to devs who need this function.
What chip have you got, if it's anything like SB/IB it's only available on some models, not all of them. I know my 4770K had the option in the BIOS.
Edit: Saying that, the 4770K doesn't do VT-d, though I think this was the case for SB/IB as well?
the 4770k, yes its in the bios but not on the cpu. Its appears to be in lower end cpus but not the top one. I better saving for ivy-e or haswell-e.
Wasn't it the non K versions of the CPUs for SB/IB that had the virtualisation stuff? Looking at the 4770 and the 4770K it seems to be following the same route as well.
im in a similar boat, im getting a 4570 instead of a 4670k because of the lack of VT-d, so annoying they disabled virtualisation on overclocking chips :/
I'm a bit lost here - what is you need to run Hyper-v you can't get on a 'k' CPU?
My current understanding is you can't get VT-d, but what do you really need it for? I'm not sure I have any specific hardware I would want to pass to guest VM.
I have some hyperv requirements as well - so want to check I don't get caught out.
Thanks
I would think VT-d is probably needed to pass stuff like the host machines NIC to the VM and if your running a dedicated virtual machine host such as Hyper-V or VMware it would be a desirable feature. Possibly the local optical drive if you want to install software via that rather than mounting an ISO.
Return it and buy SB-E and learn from YOUR mistake of not investigating into it properly.
On a related note, somebody at intel needs to address their addiction with product segmentation because it's beginning to get out of hand.
