Intel Sunny Cove(Ice Lake and Comet Lake) examined in more detail
Caporegime
9 Nov 2009
Planet Earth
Very good for the laptop market and it's gonna be interesting to see what this new architecture is capable of. I suspect their "up to 4.1 GHz" claim might be taking a leaf out of AMD's book, i.e. we won't actually see any chips that hit that speed for more than a second. I notice they're officially supporting DDR4 @ 3200 MT/s too, something they've never done with their Skylake derivatives.
Was the last time Iris Pro graphics were seen in Broadwell-C?
Intel claims an ~18% IPC improvement, which means that their "up to 3.9 GHz" @ 15 W Ice Lake-U parts wouldn't quite match their "up to 4.9 GHz" @ 15 W Comet Lake-U parts, unless of course they have better sustained frequencies relative to the 14nm parts. They're also stuck on 4 cores whereas Comet Lake-U will probably have up to 6. The 9 W versions and improved graphics look tasty though.
Doesn't bother me since I don't have a laptop.
But these 10nm chips are still exciting for low power laptop users.
You can have a ultra thin or high battery life unit while still maitaining great performance.
Even though it's 4c/8t - at 3.8/3.9ghz and just using the Geekbench results we've seen - they are on par with a gaming 5ghz i9 laptop in single thread
Anandtech preview an Ice Lake based laptop:
https://www.anandtech.com/show/14664/testing-intel-ice-lake-10nm
They used 3733MHZ DDR4 and the Coffee Lake systems used 3200MHZ DDR4,but it is unclear if the RAM was run at that speed or 2133MHZ.
However,the model tested was $426:
https://twitter.com/IanCutress/status/1156941140286955521
This is for a 4C/8T model - it appears anything over 6C for mobile is still based on Coffee Lake.
Its lucky for AMD Intel is still stuck at 14NM for desktop,and Ice Lake is still only a 4C/8T CPU.
dont be daft, the reason for lower clocks is the tdp limit. on desktop where they can pull 80+w of power wont be surprised if base clock is 5ghz.
If they could get anywhere near that they'd be releasing them on desktop, there's only one sku with a base clock higher than 1.3ghz
Unless they call the maximum boost clock of a single core "base clock", this new 5 GHz "base clock" is technically impossible.
My Ryzen 5 2500U has a documented "base clock" of 2 GHz, but most of the time sits at 1.47-1.50 GHz, with boosts to 3.00 GHz, and very rarely maximum turbo clocks for 1 core of 3.60 GHz.
SPEC2017 is another one of those benchmarking tools that claims its a measure for real world performance but uses its own code IP.
Every generation since Ivy Bridge Intel have used benchmarking tools to claim a 15% IPC increase that then turned out to be 3% in the real world.
Having said that the 1065G7 looks impressive on the face of it, its scoring 461 ST in Cinebench, that's at 3.9Ghz, yet somehow with Intel's "+18% IPC" rhetoric i was expecting more than that, i score 482 at 4.1Ghz, that's 5% higher clocked than Ice Lake with 5% higher score.
So Ice Lake matched Zen 2 IPC, and that's not "+18% IPC" its about 10%.
I also think by the time this gets to Desktop we will be talking about Ryzen 5000
