Interference with Wireless Keyboard driving me mental
9 May 2022
London
I have a CHERRY MX 8.2 TKL WIRELESS keyboard and every hour or so the keyboard will just on an absolute mental, either missing key inputs, addings its own and just generally behaving madly. After about a minute of this it sorts itself out and goes back to normal.
It does this in both Wireless (2.4ghz) mode and in Bluetooth mode. I had very similar issues with another wireless keyboard a few years ago. I specifically got the keyboard for it's wireless functionality but now end up using it wired to avoid the headaches.
How does one go about troubleshooting something like this ? I've literally got the dongle sat right next to it, i've disconnected all other wireless devices and it still does it. It's not the keyboard being broken either as I took it to a mates and it works perfectly in his house with no drops whatsoever.
I don't have issues with wireless mice or joypads or anything like that, just this keyboard.
Any suggestions welcome, perhaps there is some software out there that can analyse the wireless connections in my house and find the issue ?
Bit weird it is happening so often - tends to rule out things like wireless doorbells (or some really old doorbells where the motor creates a massive amount of EMI briefly) or baby monitors, etc. interfering which are more commonly the cause. Do you live near an emergency services depot or anything like that as they tend to create quite a lot of wide band interference. There are some people using illegal Bluetooth broadcasting devices for advertising purposes which can cause disruption.
TBH you'd probably need something which can scan a wider spectrum to see if some device is causing interference.
If it’s both 2.4 and Bluetooth it’s significantly more likely a fault with it than a local network causing interference.
Even if it was a local interference, unless it was your kit there’s nothing you could do anyway.
The odds of the same person having two potentially very different keyboards exhibit the same issue years apart seem questionable, I would be considering other causes.
