Intergrated or deidicated gpu
21 Nov 2018
Hi all,
I'm a bit lost as to what to for in a pc primarily used for work. Only really checking emails, Web browsing, occasionally watching films and other media and opening work files of various sizes but nothing huge.
I do want something quick and future proof.
Now do I go for a cpu with integrated graphics and no gpu or something with a gpu?
I really don't know. My budget in total for everything (not including monitors or keyboard or anything) is between £700 and £900.
Anything obvious jumping out at anyone?
integrated graphics would be fine for your use
tbh, you don't even need to spend your budget
a preowned ex-corp pc eg dell/hp/lenovo etc would be more than sufficient
For just basic tasks i'd go with integrated graphics then upgrade with a GPU if you need it in the future when the new cards are out
I would get integrated graphics, all 7000 Ryzen CPUs except for the 7500F include the graphics and all Intel CPUs except -F include the graphics.
This build would also support a graphics card, if one day you decide to game on it, but you can get a smaller case and PSU if you're 100% sure you will never need it:
My basket at OcUK:
Total: £619.81 (includes delivery: £0.00)​
I keep seeing the 14400f popping up. Would you recommend this?
The goal is to have this for a good few years and it remain nice and quick. I don't mind spending closer to the £900 mark if the chance if that increases. But obviosuly if not then I'll save the ££££
I 100% would not.
The 12600K in my build is generally cheaper and faster than the 14400F and it includes integrated graphics, while the 14400F has none.
You also run the risk of getting a CPU with a Raptor Lake die and we have no idea how broken these might be. I'd just avoid 13th-14th gen entirely until confirmed otherwise.
OK this is exactly the kind of thing I needed to know. It's so easy to get lost in the sea of cpu's and 'benchmarks'.
Thank you.
What about this 8600g then? How do they stack up against a 12600k? Being as they are almost the same cost?
If you're literally just doing web browsing and the like there's zero difference in getting a new pc and a cheaper used ex-corporate one.
The 12600K is a faster CPU, but the 8600G has much more powerful graphics if you ever want to play games on it. The overall cost of a 8600G build will be a bit higher though, because you'd need DDR5 and the boards tend to be more expensive (depends on which one you buy).
AM5 will also have more future CPU upgrades available, since AMD have confirmed they'll support AM5 for another 2-3 years. Realistically though, I don't think you'd need a new one for basic desktop use within 5-10 years.
I noticed you opted for dd4 over ddr5. I know for what it's used for it may not make much difference, is this simply the reasoning? Obviously with ddr5 becoming more accessible, is it still not viable over ddr4 in this instance?
Yeah partly, but OCUK have very few Intel DDR5-capable Micro-ATX or ITX motherboards and I didn't think it was worth going full-size ATX for a PC you don't even intend to put a graphics card into.
For your budget, the cost isn't an issue, since you can get everything you want AND DDR5 too, it was just convenience and availability.
One of the cheapest DDR5-capable boards is Asus B760M-K (D5 version), or if you want something more fancy with wifi, e.g. MSI B760M Gaming Plus Wifi. Obviously wise to check they have the slots, USB ports and display outputs that you prefer before you buy one.
IMHO for your needs, you dont even need to buy new... You can get away with paying a fraction of the price of new and still have a more than capable future proof PC.
I keep splashing out on the best of the best only to realise that the thousands I have spent on it can be beaten in less than a year by something for a much lower price.
The ONLY reason to get really high end stuff, is for seriously high end gaming but again, there is nothing thats out there that wont play one a PC that just cost a couple of hundred ( admittedly, in 640x480 and all details on minimum LOL ).
