- 26 Aug 2010
- West Yorkshire
I'm looking around to see if anyone knows of any good fully internal fan controllers (i.e not ones that you use externally from the front panel, or one sitting on a desk.) I have a 900D so i don't want to be taking off the front as it doesn't look that good
I'd want to control it through switches/dials inside the back of the case, or through software as that would keep it out of the way.
I have no budget as such, but the cheaper (but not so cheap that it is tacky) the better.
