Probably, but you would need a filter in front of the fan. The Scythe Kama bay is probably a better option, although you won't get the 5.25" to 3.5" HD cage. Or if you could fit mesh faceplate covers then you can get the CM Module.
Well actually I want to be able to have a couple of hard drives in the bays. So would I be able too, having fitted the Scythe Kama bay. Would there be enough room?
If using the Kama you'l need to mount the 3.5" HD's in the area behind the fan, so either use elastic, or 5.25" to 3.5" railings (no sound absorbtion with these though)
