Internal Scratch Removal?
Man of Honour
21 Feb 2006
Got some very fine scratches on my dashboard wood (read crappy plastic wood) trim and I wondered if anyone has any tips for removing them, they are annoying me. Tried some Meguiars scratch X and that didn't touch it, probably made worse actually.
Any pointers?
ScratchX is quite abrasive. I would probably try something like PlastX which is designed for getting fine scratches out of plastic.
If's it's just a piece of trim then it might be cheaper to replace the trim than keep trying different products.
It's the bit that runs up the side of the cup holder draw near my leg that looks the worst but as you can see on this photo is doesnt show in most lights.
I shant be wrapping it chaps, but now you've seen it you perhaps appreciate why. :)
