Internet Problem
8 Aug 2009
Swindon :'(
My friend, when playing Black Ops. suffers unbearable lag whenever he is in a game. We can never connect to eachothers partys and he lives a couple of doors down from me. His ISP is Virgin and the internet is fine while he is browsing the web. Help would be appreciated.
the Virgin Router is supposed to have UPNP which means that the ports for xbox live can be opened automatically. But it doesnt work properly on the virgin firmware.
Only way i could get UPNP to work properly with xbox live on my router, was to install the DD-WRT firmware.
Are you reasonably techy ? If so read up and do it for him. He'll be eternally thankful :D
http://www.cableforum.co.uk/board/87/33663196-guide-dir-615-to-dd-wrt.html
Just need to find the correct up to date release for his revision of the DIR-615
Download here
http://www.dd-wrt.com/site/support/router-database
Just make sure you check the sticker under his router to ensure you get the correct firmware for his revision of the hardware.
