Internet speed test
One of the worst and gives unrealistic results.
Agreed. I've got 900Mbps BT FTTP on a 1Gbps internal network yet apparently my internet speed is:
So, how do you test the speed you are getting from your ISP is what you should?
If you have signed up to a service, let’s say for example 80/20 and you download a file from somewhere and you get max speeds that’s how you know your internet is working.
You can do a speed test (make sure the pc is by Ethernet cable) on many sites to see if your internet speed is what you are buying.
It’s not a hard concept to understand.
But which site would you recommend?
That's what's being asked and so far you've just provided some pointless smart arse answers.
I am on 900/100 package. So, what should the max speed be and from what site for example.
Then you should be getting 900Mbps max on download and 100Mbps max on upload.
Pick a website from the Google results search first page and test.
Make sure a cable is plugged in and not over WiFi. Unless you are on WiFi6/ax and not far away from the router to achieve and max out the connection.
