Interview test for assistant network manager - what types of technical questions do you think they w
common one is:
entire class cannot work as the network is down
one student needs his password reset
headteachers printer doesnt work
which one do you deal with first and why.
According to my school it would be 1, 2, 3 as everything has to come down to teaching and learning that directly effects the students.
However in the real world I would be shot if I did 2 before 3. I MIGHT get away with doing 1 first!
Probably the usual stuff: TCP/UDP ports, stuff like FSMO roles (if Windows is included), DNS, Group Policy questions, VMware (if this applies), maybe basic IIS stuff. Exchange things? eseutil common flags, etc.
TCP/IP IS addressing ;)
VLANS, switches, subnetting,basic routing at a minimum, depends on what they are looking for tho, some network manager roles are MSOFT domain admin roles, you would be well placed if you know the meat of the stuff tho as well as the frippery (MSOFT etc ;) )
NATing could be worth looking into as well. But as above it depends on what they are looking for
If you are getting TCP/IP wrong I suspect you might not be right for it IMO - thats like a mircosoft engineer not knowing what Windows is
Best of luck though :)
e: maybe look into the differences between IPV4 and IPV6 as well
In my school I always make sure all senior staff have access to a backup networked printer, just in case. I'd always prioritise a downed network over the Headteacher's printer any day, and I'd argue the point afterwards as well. Thankfully though my Head is a sensible woman, so this is a point that would never come up.
Well if the whole network was down that could be the reason the headteachers printer wasnt working, so 1 would always be first.
All staff have access to all printers (over 40 of them), and there are 600 PCs in the school to use. I would sort the downed network first however I might be questioned on the time it took to sort her printer! She is reasonable/sensible but it would be raised.
When I questioned it in a recent SLA meeting with my boss he said that the reason would be that she is running the school and it would all fall apart without her, not only that but for all I know she could be printing documents for an ofsted inspector in reception.
In reality it wouldnt be an issue as I would send my colleague to do the network and I would sort the printer, not to mention the fact she has a PA and a Secretary each with a printer!
Not necessarily. In our place at least we're split over about 10 buildings, so the network could be down in one building due to a switch issue (or more likely, a cleaner has unplugged the cabinet to plug in a vacuum or something), while leaving the rest of the school unaffected.
Yup, same here, plus our photocopying technician is 4 doors down from the Head as well, so there's never someone far away who can print.
