OcUK Staff
- 26 Nov 2014
- Stoke
We're pleased to introduce a new brand to OcUK - Kolink. Kolink aim to offer a range of products that are feature rich yet affordable. We are launching a range of cases and 80+ Bronze certified power supplies initially. The cases offer a range of features usually found on more expensive cases. Highlights include the Victory, offering an attractive brushed aluminium effect front bezel, with a 12cm Blue LED fan and USB3.0 included as standard, the Octagon with 3 included fans (2 x 12cm Blue LED), card reader, fan control, USB3.0, side window and the Aviator, available in 3 colours to suit your preference.
Added to this we have introduced 3 power supplies from Kolink, ranging from 400W to 600W, all officially 80+ Bronze Certified, meeting the EU regulations for efficiency of all units sold within the european union. These units are solidly made and come with at least 1 6+2 PCI-E connector (2 on the 500W/600W units) to power the latest graphics cards.
The Victory, KLM-001, Octagon and Deathclaw are currently in stock, along with the 3 PSU models. The Aviator and Satellite will be in stock early November.
Kolink Victory Micro-ATX Gaming Case - Black @ £22.99 inc VAT
The Kolink Victory has arrived, sporting an attractive front panel design, with brushed aluminium effect finish, a 12cm Blue LED fan and USB3.0 support to boot. The Victory can support up to 330mm VGA cards, 155mm CPU's and ATX PSU's in a Micro-ATX form factor.
The Kolink Victory is a small tower packed full of features and would be a great case for a compact gaming build.
Features
- Micro-ATX Gaming Case
- 1 x 12cm Blue LED Fan installed
- VGA support for up to 330mm and 155mm for CPU Cooler
- Black interior
- USB3.0 Port on the front I/O
- Brushed aluminium effect front panel
Specifications
- Model: Victory
- Type: Micro-ATX Gaming Case
- Case Material: 0.5mm Steel/Plastic
- Power Supply Orientatation: Top
- Motherboard Support: Micro-ATX/Mini-ITX
- External 5.25" Bays: 0
- External 3.5" Bays: 0
- Internal 3.5" Bays: 1
- Internal 2.5" Bays: 1
- Expansion Slots: 4
- Front Ports: 1 x USB3.0, 1 x USB2.0, HD-Audio x 1, Mic x 1
- Cooling System: Front - 1x 120mm Fan (included Blue LED), Rear - 1 x 80mm/90mm (optional)
- Dimensions: 380 x 170 x 370mm
- Clearance: VGA - 330mm, CPU Cooler - 155mm
Only £22.99 inc VAT.
ORDER NOW
Kolink Octagon Midi Tower Gaming Case - Black @ £39.95 inc VAT
Introducing the Kolink Octagon, an imposing gaming case with an impressive set of features for the price. The Octagon comes equipped with 2 front 120mm Blue LED fans and a rear 120mm fan for good airflow out of the box. The internal structure is spacious and offers support for up to 380mm VGA, 160mm coolers, and space for 240mm radiators on the top and front. Furthermore, the Octagon comes with an attractive triangular side window to show off your build in style.
The Kolink Octagon comes with a USB3.0 port as stand and also has fan control and SD card reader functionality to suit all needs. The Kolink Octagon represents outstanding value for money and is a great choice for anyone looking for a great looking gaming case on a budget.
Features
- Midi Tower Gaming Case
- 3 x 12cm fans preinstalled (2 x 12cm Blue LED)
- SD Card Reader and Fan Controller installed as standard
- Support for 240mm Radiators on the front/top of the chassis
- VGA support for up to 380mm and 160mm for CPU Cooler
- Triangular side window
- Black interior with cable management and toolless bays
Specifications
- Model: Octagon
- Type: Midi Tower Case
- Power Supply Orientatation: Bottom
- Motherboard Support: ATX/Micro-ATX/Mini-ITX
- External 5.25" Bays: 2
- Internal 3.5" Bays: 3
- Internal 2.5" Bays: 2
- Expansion Slots: 7
- Front Ports: 1 x USB3.0 (with USB2.0 convertor), 1 x USB2.0, HD-Audio x 1, Mic x 1, SD Card Reader, Fan Controller
- Cooling System: Front - 2 x 120mm Fan (included Blue LED), Side - 1 x 120mm/140mm (optional), Rear - 1 x 120mm (included), Top - 2 x 120mm (optional)
- Dimensions: 400 x 180 x 445mm
- Clearance: VGA - 380mm, CPU Cooler - 160mm
Only £39.95 inc VAT.
ORDER NOW
Kolink KLM-001 Micro-ATX Case - Black @ £22.99 inc VAT
The Kolink KLM-001 is a budget focussed Micro-ATX chassis aimed at business and home office solutions. The KLM-001 has a brushed aluminium effect front panel for a professional look, and is equipped with a USB3 port on the front I/O. The KLM-001 also sports a black interior and a rear 80mm fan.
The Kolink KLM-001 is an ideal choice for anyone looking to build an office based PC on a budget.
Features
- 1 x USB3.0 on the front I/O
- Black Interior
- Rear 80mm Fan
Specifications
- Model: KLM-001
- Type: Micro-ATX Tower
- Case Material: Steel/Plastic
- External 5.25" Bays: 1
- External 3.5" Bays: 1
- Internal 3.5" Bays: 2
- Front Ports: 1 x USB3.0 (with USB2.0 convertor), 1 x USB2.0, HD Audio x 1, Mic x 1
- Cooling System: Front - 1 x 120mm (optional), Side - 1 x 120mm (optional), Rear - 1 x 80mm (included)
- Dimensions: 350 x 175 x 352mm
ORDER NOW
Kolink Deathclaw Midi Tower Gaming Case - Black @ £29.99 inc VAT
Prowling the wasteland of the budget computer case market, the Kolink Deathclaw destroys the opposition with a combination of features and looks. It comes pre-installed with 3 fans, 2 of which are Blue LED, 1 x USB3.0 port on the front panel, a L shaped side window to show off your components and even supports up to 400mm VGA cards.
With the addition of a black interior with room for cable management, a toolless 5.25" bay and bottom mounted PSU, the Deathclaw is a formidable gaming case at an aggressive pricepoint.
Features
- VGA support for up to 400mm and 158mm for CPU Cooler
- L-Shaped side window
- Black interior with cable management and 5.25" Toolless Bays
Specifications
- Model: Deathclaw
- Cooling System: Front - 1 x 120mm Fan (included Blue LED), Side - 1 x 120mm (included Blue LED), Rear - 1 x 120mm (included)
- Dimensions: 450 x 185 x 412mm
- Clearance: VGA - 400mm, CPU Cooler - 158mm
Only £29.99 inc VAT.
ORDER NOW
Kolink Aviator Midi Tower Gaming Case - Gunmetal @ £42.95 inc VAT
With it's aggressive gaming design, the Kolink Aviator is an excellent example of a gaming case that is packed full of features without the hefty pricetag. The Gunmetal Aviator comes with a premium matte finish, and 3 pre-installed fans, 2 of which are Blue LED. The Aviator comes with support for up to 370mm VGA cards, 170mm CPU Coolers and 240mm Radiators on the top or front panel. Furthermore, the Aviator comes with 2 x USB3.0 ports at standard, an TF/SD Card Reader and a fan controller for excellent user interface options.
The Kolink Aviator is an excellent Midi Tower gaming chassis and represents outstanding value for money within the gaming range.
Features
- 2 x Front USB 3.0 with audio jacks
- Extruded right side panel for cable management & better airflow.
- Large hexagonal mesh on front and top for good airflow.
- Equipped with a stylish pedestal that lifts your chassis and improves airflow.
- Bottom PSU placement.
- Tool free SSD, HDD side installation.
- TF/SD card reader ready for quick access to multimedia.
- Tinted transparent ABS window for full view of interior.
- Dual radiator water cooler installable (top and front)
Specifications
- Model: Aviator Gunmetal
- Colour: Gunmetal with matte front panel finish
- Front Ports: 2 x USB3.0 (with USB2.0 convertor), 1 x USB2.0, HD-Audio x 1, Mic x 1, SD Card Reader, Fan Controller
- Cooling System: Front - 2 x 120mm Fan (included Blue LED), Rear - 1 x 120mm (included), Top - 2 x 120mm (optional)
- Dimensions: 400 x 211 x 480mm
- Box Dimensions: 578 x 263 x 538
- Clearance: VGA - 370mm, CPU Cooler - 170mm
Only £42.95 inc VAT.
ORDER NOW
Kolink Aviator Midi Tower Gaming Case - Black @ £42.95 inc VAT
With it's aggressive gaming design, the Kolink Aviator is an excellent example of a gaming case that is packed full of features without the hefty pricetag. The Black Aviator comes with a premium Glossy finish, and 3 pre-installed fans, 2 of which are Red LED. The Aviator comes with support for up to 370mm VGA cards, 170mm CPU Coolers and 240mm Radiators on the top or front panel. Furthermore, the Aviator comes with 2 x USB3.0 ports at standard, an TF/SD Card Reader and a fan controller for excellent user interface options.
Features
Specifications
- Model: Aviator Black
- Colour: Black with glossy front panel finish
- Cooling System: Front - 2 x 120mm Fan (included Red LED), Rear - 1 x 120mm (included), Top - 2 x 120mm (optional)
ORDER NOW
Kolink Aviator Midi Tower Gaming Case - White @ £42.95 inc VAT
With it's aggressive gaming design, the Kolink Aviator is an excellent example of a gaming case that is packed full of features without the hefty pricetag. The White Aviator comes with a premium Glossy finish, and 3 pre-installed fans, 2 of which are Blue LED. The Aviator comes with support for up to 370mm VGA cards, 170mm CPU Coolers and 240mm Radiators on the top or front panel. Furthermore, the Aviator comes with 2 x USB3.0 ports at standard, an TF/SD Card Reader and a fan controller for excellent user interface options.
Features
Specifications
- Model: Aviator White
- Colour: White with glossy front panel finish
Was [OLDPRICE] Inc. VAT
ORDER NOW
Kolink Satellite Micro-ATX Cube Case - Black @ £26.99 inc VAT
The Kolink Satellite is a cube style chassis with impressive amounts of component support, including up to 280mm VGA, ATX PSU up to and even Micro-ATX boards up to 22.6cm x 18cm. The front I/O is equipped with 2 x USB3.0 ports for high speed transfers, and there is internal space for various drive configurations to suit your requirements.
The Kolink Satellite aims to offer impressive functionality with a small case footprint and competitive price. It delivers on all counts.
Features
- 2 x USB3.0 on the front panel
- Support for Micro-ATX Motherboards
- Support for 280mm VGA cards
- Small footprint
- Space for 2 x 3.5" + 2 x 2.5" or 3 x 3.5" or 4 x 2.5" HDD's
- Black Interior with 12cm rear fan installed.
Specifications
- Model: Satellite
- Type: Micro-ATX Cube Case
- Colour: Black
- Power Supply Orientatation: Front
- Internal 3.5" Bays: 3 (dependant on configuration)
- Internal 2.5" Bays: 4 (dependant on configuration)
- Expansion Slots: 2
- Front Ports: 2 x USB3.0 (with USB2.0 convertor), HD-Audio x 1, Mic x 1
- Cooling System: Rear - 1 x 120mm (included)
- Dimensions: 260 x 190 x 280mm
- Clearance: VGA - 280mm, CPU Cooler 165mm, PSU - 220mm (with VGA card under 190mm), 140mm (with VGA card over 190mm)
Only £26.99 inc VAT.
ORDER NOW
Kolink KL-400 400W '80 Plus Bronze' Power Supply @ £25.99 inc VAT
The Kolink KL series are 80 Plus Bronze certified power supply units aimed at the budget system build, offering reliable power without a hefty price tag. The KL-400 is able to deliver 400w of continuous power at 80 Plus Bronze efficiency over a single rail, and features multiple protections such as OVP, UVP, SCP, OPP and OTP.
The KL series all meet the necessary EU requirements for standby wattage and efficiency. They all contain a low noise 12cm fan and have 1 x (400W) or 2 x (500W/600W) PCI-E 6+2 pin connectors for GPU support. The Kolink KL series PSU are a perfect combination of reliability and functionality, backed up with a 2 year warranty for peace of mind.
Specifications
- Power supply: Full range 100V - 240V / 50-60 Hz
- Wattage: 400W
- Compliance: AMD, INTEL ATX 2.92 2.3/EPS, 80 Plus Bronze Certified
- Silent 12cm fan cooling
- High performance components for improved reliability
- Eco-friendly design to meet Elot3
- Support PCI express - 1 x (400W) and 2 x (500W/600W)
- Intelligent temperature control,Noise: <26dB
- Multi-Protection OVP, UVP, SCP, OPP, OTP
- Time MTBF: 100,000 hours minimum
- 80+ Bronze APFC high efficiency: minimum 85% efficiency at 50% load, 82% efficiency at a load of 20% and 100%
- Power consumption in standby <0.5 W
- Temperature: 40 ° C
- Dimensions: 86mm (H) x 150mm (W) x 150mm (D)
- CE/RoHS approved
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 1 x 6+2-Pin-PCIe
- 3 x SATA
- 2 x 4-Pin-Molex
- 1 x FDD
- Warranty: 2yr
Only £25.99 inc VAT.
ORDER NOW
Kolink KL-500 500W '80 Plus Bronze' Power Supply @ £31.99 inc VAT
The Kolink KL series are 80 Plus Bronze certified power supply units aimed at the budget system build, offering reliable power without a hefty price tag. The KL-500 is able to deliver 500w of continuous power at 80 Plus Bronze efficiency over a single rail, and features multiple protections such as OVP, UVP, SCP, OPP and OTP.
Specifications
- Wattage: 500W
- CE/RoHS approved
Connectors
- 2 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- 1 x FDD
- Warranty: 2yr
Only £31.99 inc VAT.
ORDER NOW
Kolink KL-600 600W '80 Plus Bronze' Power Supply @ £36.95 inc VAT
The Kolink KL series are 80 Plus Bronze certified power supply units aimed at the budget system build, offering reliable power without a hefty price tag. The KL-600 is able to deliver 600w of continuous power at 80 Plus Bronze efficiency over a single rail, and features multiple protections such as OVP, UVP, SCP, OPP and OTP.
Specifications
- Wattage: 600W
- CE/RoHS approved
Connectors
- 2 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- 1 x FDD
- Warranty: 2yr
Only £36.95 inc VAT.
ORDER NOW
Features
- Black interior
Specifications
- Model: Victory
ORDER NOW
Features
Specifications
- Model: Octagon
ORDER NOW
Features
- Black Interior
- Rear 80mm Fan
Specifications
- Model: KLM-001
ORDER NOW
Features
Specifications
- Model: Deathclaw
ORDER NOW
Features
Specifications
ORDER NOW
Features
Specifications
ORDER NOW
Features
Specifications
ORDER NOW
Features
- Small footprint
Specifications
- Model: Satellite
- Colour: Black
ORDER NOW
Specifications
- Wattage: 400W
- CE/RoHS approved
Connectors
- 1 x 6+2-Pin-PCIe
- 3 x SATA
- 2 x 4-Pin-Molex
- 1 x FDD
- Warranty: 2yr
ORDER NOW
Specifications
- Wattage: 500W
- CE/RoHS approved
Connectors
- 2 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- 1 x FDD
- Warranty: 2yr
ORDER NOW
Specifications
- Wattage: 600W
- CE/RoHS approved
Connectors
- 2 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- 1 x FDD
- Warranty: 2yr
ORDER NOW
