Huntkey is the OEM. Work with Dell and the rainforest in the US amongst others so must be doing something right![]()
That doesn't give a lot of confidence. First link I found on google doesn't read favourably for them either.
They've upped their game in the last few years. Pre 2012, i'd tend to agree.
None of which are the psu's for sale here.
Good spot, it's 220mm with a VGA card under 190mm, 140mm without. Generally the Satellite will take the majority of Micro-ATX boards but inevitably with it being a small chassis there may be some strangely sized boards that won't fit.
Do those cases come with free bin liners?
Now I am getting confused!
The first board I looked at... the Asus Z97M-Plus is 24.4mm x 22.4mm so I guess that would be too large.
Are you aware of any Asus Micro-ATX boards which would fit OK into this particular case?
Thanks!
Edit: I have also been looking at the Asus mini-ITX Z97I-Plus board which is 17cm x 17cm but at just under £150 it ain't cheap!
Ah well, back to the drawing board!![]()
H81M models fit, I checked with the factory and can confirm it will take Micro-ATX boards up to 23cm x 19cm, but with having 2 expansion slots, only single card setups will be possible.
