Heres The Thread I posted in when I got my INWIN 101
https://forums.overclockers.co.uk/threads/in-win-101-midi-tower-case.18782256/
This Thread is Full of INFO
Great Case With very easy Quick Rel Glass Panel
Pull out pins maybe stiff first time being first time used
PSU up top so No Dust will get into the Fan
Setup without Rads
120MM Fan rear for Exhaust
Front side 2x 120mm side-fans as Intake
Setup with Rads
Front side 240mm Rad Exhaust
Bottom Rad Exhaust
Sata Power connection coming from the top Front Panel Behind Motherboard Tray Lights Up the Acrylic INWin logo on front top Right,
Use a SATA Power Connector Coming from your PSU to connect to the case SATA Connector,
Otherwise, you can leave it disconnected.
That is why there are no + / - Power LEDs wire pins
Reset switch is dying out in a lot of cases for some time now
That why no reset Pin Wire
Still, Use the USB 3.0 internal Header if your motherboard as a 3.0 header & also if your motherboard got good Built-in Audio,
connect the Case Audio Header to the motherboard
Other wise connect it to the soundcard like sound blaster Z
I have the Gigabyte z370 mobo... My old build was a ryzen and had AB350-N mobo...
I will be getting some headphones on boxing day as the missus has got me vouchers so may get a set of Corsair Voids or one of the Steelseries models.
The New Creative Sound BlasterX AE-5 More Geared up for Headsets , But I don't think there be much more Sound Gain, Motherboard Onboard good Enough
