Ionic Fan - Is it really this easy?
18 Oct 2002
Sandwich, Kent
Just been reading this....
http://www.inventgeek.com/Projects/IonCooler2/Overview.aspx
Watch the movie clip. I was expecting a virtually non existant whaft. :eek:
http://www.inventgeek.com/Projects/IonCooler2/Images/P1010384.MOV
Is it really that easy to make a ionic fan like that. If so that HAS to be my next mod!
I higly doubt thats real. I saw another mod with someone who made an ionic wind cooled computer. However soneone did the maths on itl, and revealed it all as a fraud.
Looks real to me, have a look at some of his other projects, why would anyone bother making how-tos if they didnt work?
I had a look in one of these ionizer things in an electrical shop last night and it does look very much like the only thing generating the whoosh of air is a couple of wires. I've been trying to track down an ion generator but no luck so far.
Ditto - If it really was this easy then why have NASA only begun to deploy experimental ion drive spacecraft which are essentially the safe technology (OK slight variation on application, but physics and principle are the same)
Would it even work in space?
technically no as theres to air in space to create the thrust, thats why the crafts use a xenon gas mix of whatever kind.
would be nice to try this but wouldn't it require quite a large voltage to compare with a fan? and even then, ude have a levitating PC right? :p
disclaimer: warning, im not a physicist, under no cirrcumstances take my words as gospal, i have read these things up as general interest but have a bad memory so i may be wrong, im no Einstein
I dont actually see what is being disputed here, you can buy ionic fans, he has made one and put it on the back of a computer, and it _is_ moving air, which is all he claims, he also says the strips are so lively, because theyre made out of almost nothing(cant remember what, mylar I think)
The spaceship has no relevance what so ever, its like almost like saying petrol engines arent real because nasa cant make an engine fuelled by water. And also how do you know nasa dont have an ionic drive spaceship?
I think it would work, and nasa probably are developing one.
Well I've now ordered all the parts required to build this.
Just gotta wait for the Ion generator to be delivered. I bough the same one he used.
Dont think I'll try this on my new C2D rig though. :p
Why would NASA spend millions developing rocket engines when they could just use a ducted fan..... :rolleyes:
So the air is ionised and attracted to the second wire? What happens to it then? Presumably it returns to it's ground state. I wouldn't be happy with a room full of ionised air. End up with lightning :eek:
i read sumwhere that ionising air reduces polution in it...or something along those lines, ill see if i can find it...
would mean a very healthy PC :)
wonder, would ionising air do something with the dust? like for example, repel it away from the PC somehow? or even attract it to the wires and act as a filter?
I cant see how this will make a lot of air movement. Ionic generators are used in marine aquiriums to clean the water. They generate and electrical charge and this cannot be good for computers as static charges aint good for computers. If you go outside after an electrical storm and smell the air it is the ion charge in the air that toy will smell. I used the same principal while keeping marine fish to kill bacteria in the tank. :o
Me neither. I was expecting the faintest waft. But then I saw the video. Its one of those things that unless you see it in the flesh, you'll never beleive it.
The guys original design was to have the unit inside. When people pointed out the charged ions may effect the machine, he moved it outside for his V2.
