it's not difficult, when you plug in your iDevice select it from the left panel and the screen in the middle has some options like:Is it possible to sync your iDevice with itunes without having the usb cable connected?
Would be very keen to know if this was possible![]()
Without
cant for the life of me get this to work
Works fine for my with my iPhone, iPad and iPod Touch, although can be a bit flaky from time to time.
Find it most useful with the iPad to be honest as, since it won't charge from a USB socket, I have the dock plugged into the mains charger and use WiFi to sync it.
Both, apparently it charges if the screen is off 'very very slowly'Really? is that the iPad 1 or 2?
oh my gosh!
Connect the iDevice to the network via WiFi.
Plug it in via a cable.
Open iTunes
Tick the box that says "Sync with this iPhone over Wi-Fi"
Unplug the phone, close iTunes and re-open it!
If this doesn't work then you have a problem with something else!
