Permabanned
- 9 Aug 2008
yep done all this, wont sync![]()
Then you have other problems. You may be due a format.
Really? is that the iPad 1 or 2?
Strikes me as a fairly useless bit of design from Apple. Why couldn't they have provided some kind of splitter cable that lets you connect it to the mains charger for power and the USB for connectivity at the same time?
Wouldn't that just be 2 USB cables? might as well plug it into the wall and let it wifi sync.
Can we just varify that this guy is connected to the same wireless as his pc and that by "online" he's not tryin to sync through 3G?
There is no logical reason for it not to work mate
GJ02 I think your missing the concept of IOS 5 WiFi sync.
Can you see your phone in iTunes at all when it's not plugged in?
iPad 2. Apparently most PC USB ports just can't supply enough juice and it says "Not charging" in the top corner. I've heard it might trickle charge really really slowly but prefer to keep it on the mains charger and use WiFi to sync.
Have you tried starting the sync from both iPhone and iTunes? From iPhone you can start it from Settings App -> General -> iTunes Wifi Sync -> Sync Now. I had problems with this being greyed out for a while, it seems to have fixed itself though so I'm probably not much help!![]()
