IP Adress
17 Dec 2009
Wales
Looking for a way to make my computers IP adress stay the same . ie static . Got a belkin router any idea how to do this?
This anything to do with it?
That's something to do with it, in that those are options for the router's DHCP server, but that's just the range of address it dishes out.
Unless your router gives you options to configure static mappings, or whatever Belkin might call them, then you'll need to configure manual IP address settings for the adapter in Windows.
IP address 192.168.1.101 (outside that DHCP range)
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1 (assuming that's the IP address of your router)
If you mean your external IP then im pretty sure that will be down to your ISP
But as above internal ips can be set for different machines in a network
Control Panel > Network and Internet > Network and Sharing Center > Change adapter settings > Right-click the relevant adapter and choose Properties > Select TCP/IPv4 and choose Properties
Enter the details there. Also set Preferred DNS server to the IP address of your router.
Bear in mind if you need to connect to any other networks, for instance if yours is a laptop which gets used at work or elsewhere, then those settings might not be appropriate and will need reverting.
Does your router support DHCP reservations?? If so it's easier to reserve the address on the router and leave all the PCs set to DHCP.
Show us a screenshot of the options. Should show the MAC address of the adapter and the IP address you want assigned to it.
That just determines the length of a DHCP lease, I guess it doesn't stop a computer reconnecting to the network and being issued with a new lease. It's not the same as a static mapping or a DHCP reservation.
Just did this , Changed a few things to what they needed to be , as you can see I can acsess the internet fine , does this mean my computer now has a static IP?
turn off dhcp on the router and set a static ip within the properties of your lan connection in network in control panel, goto tcp/ip settings and click properties button. add static ip within the range of the now disabled dhcp range.
that is only an internal ip address though.
if you want a static ip on the internet that costs a lot of money, what you can use for that is dynamic dns.
edit due to your response: you would have to do a disable and enable to the lan adapter to activate the change or do an ipconfig /renew in cmd
get this now when I try to get on my router admin cp
EDIT: Fixed with router re-boot.
Will this affect other computers on the network (acsess to internet)..
EDIT: did this and the connection on the other computer broke , does this have to be done?
No it doesn't and it's bad advice. That subnet mask and that DHCP range leaves plenty of other addresses to play with.
Ok thanks , reset the settings and the other computer is back up now , one thing though . On the router list of connections page it shows my pc with the same IP as before and not the new one I manually assigned ..
That's probably just showing the current leases, not necessarily all the devices that are connected. Worth setting the lease time back to whatever it was, you don't really want it set to forever.
