IP35 CPU Temp issues
Man of Honour
17 Oct 2002
Hi guys,
Just put an IP35 Pro XE into my other machine. It has a Freezer 7 Pro and an E4300. Everything is stock at the moment.
According to the BIOS, the CPU temp whilst in the BIOS is 54c. As a result, in Windows, it constantly kicks the fan in and out.
I presumed at first the heatsink wasn't seated correctly so I took it all apart, redid the AS5, reinstalled. No change.
Interestingly, CoreTemp run within Windows reckons both cores are just 32c.
So whats going on here? Which is the more accurate temperature? I always thought Coretemp was more accurate and would normally show HIGHER temps than the motherboards CPU temp monitor?
Could I have a faulty motherboard?
Thanks!
Cpu usage is high when the BIOS is loaded, theres no Operating system supported APM in place like stop grants and idle cycles, might even be 100% load if i remember right, so the temp seen there will be on the high side.
True, but there is clearly an issue as the fan keeps kicking in and out in Windows when it shouldnt - it's set to only kick in when the CPU temp goes above 50.
Which indicates an issue.
