IP35 Teaking And Advice
12 Mar 2009
Hi All
I finally setup my new system a little while ago and managed to get it oc'd by following various instructions etc what i'd like to know is there anything I need to change and am I likely to get anymore out of it (although not overly fussed as it's stable at the moment). Also is the memory settings correct as for some reason I thought I saw a problem with one of the settings but I can't remember what it was now ha.
CPU-Z images (Slot 1&3 of memory are the same)
Hi thanks for your reply much appriciated, i'm thinking I might just stick with what I've got as it's currentlt running happily. (wimp I know) ha
Nice clocks and volts, anything more you do now will be overclocking ur fsb and memory too, so it would all depend on what ur memory can run at.
But having ur memory 1:1 and running stock is nice for overall system performance.
Its a nice clock for 24/7.
