Ipad2 advice
2 Dec 2004
Under The Desk, Wales
Bought the ipad2 today and downloaded some free games from the apple store.
Some, open in a small page and when you press x2 they look jagged and nor smooth. Is that deliberate?
Those applications will be iPhone ones.
When your searching for apps they will either be under iPad apps or iPhone apps. Some will have a '+' symbol by the price. This means that they are made to work on both. These are the best because you only pay once. But you get the developers such as the Angry Bird ones who make 'different' apps for the iPhone and iPad and therefore you pay twice.
So yes it is deliberate. I've found the majority of apps I use though to have a version for the iPad as well as iPhone.
Guys, why is it that a lot of the games i have downloaded for my daughter on the ipad2 need internet access to use? I wont have internet access in the car when we gon on hols so how will i know which games will be ok to download and not need net access?
Thanks. Just downloaded some that dont need a net connection.
If anyone can recommend some great games for a 6 year old girl that would be very helpful. Thanks
