Neither. Go for the Nokia X7 instead.
Sorry, no, it's a piece of garbage. I made the post as a joke while this thread was in GD, so please ignore itNokia X7 any good?
Are you currently sitting in a coffee shop drinking a frappuccino while designing QQQ (replace QQQ with wallpaper, speedos, minimalist furniture, or the cover of Gay Times as appropriate)? If you answered yes to this question, get the Iphone, if not get a decent android phone.
Pro Android argument:
http://lifehacker.com/5801862/top-10-awesome-android-features-that-the-iphone-doesnt-have
Someone else point out iPhone advantages. I can't be bothered.
Android if you have time to customise it.
iPhone if you can't be bothered.
I think the problem with that list is that bar the odd thing none are really any of the reasons i would choose android over apple.
I've got an iphone and an android based tablet and i think from that i would recommend an iphone purely for the swiftness of doing anything. I like the fact that there are so many games (albeit some are useless) that no train journey or wait is as boring as it used to be. From a phone i just want functionality therefore an iphone is the best option. However as said if you want to mess around customising things then go for an android based phone
However, if you are a competent user and need your phone for important tasks (constant email, tasks, agendas etc), you might begin to find the way iOS works frustrating. It isn't really geared to that kind of use right now; notifications are intrusive (they pop up and stop you from your current task), and constantly switching between apps slows you down. There isn't really any system-wide integration between apps either, so if you are using a separate RSS reader, for example, and you have to open a webpage in Safari, the only way to return to your reader is to open the app manually again.
doddsy105 said:I really like the iPhone 4, but is it really too much for a phone compared to some of the others.
