Iphone 4 stuck in recovery mode
10 Jun 2006
Wigan
Just got home from work and my girlfriend said that she plugged her new iphone 4 into itunes and it asked her to update to 4.0.2 she said all was going well but she got an error at the end and now the phone is stuck in recovery mode,
I have tried putting in DFU mode and restoring but I just get the error "The iphone can not be restored, an unknown error occurred" (1004), I click more info and that tells me to restore :mad: This just causes the loop again.
I tried googleing it but all I can get is info on jailbroken iphones, this phone has never been jailbroken and was only purchased yesterday.
Anything you can recommend would be appreciated,
Thanks
Thanks
Sounds almost the same problem as me OP, but I get error message 14.
Any update what happened?
Update:
Looks like it was a corrupted update download. Deleting the file in the folder below worked a treat.
C:\Users\**username**\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates
Yer i had this problem with the last download one way to fix is just download from a 3rd party site there are some trusted ones out there and then ATL+Click on the update button which will let you select the update from anywhere on your mac
(CRTL + Click on pc)
Could you link to a trusted site that you know of please?
