iphone 7 home button advice please.
12 Feb 2009
N.Ireland
Hi, I replaces my sons iPhone7 screen with this one.
https://www.ebay.co.uk/itm/For-Full...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
The original home button doesn't now work as you know, so I thought id try this button.
https://www.ebay.co.uk/itm/Black-iP...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
The new button doesn't make any difference. Is there a setting I have to change to enable it :)
In fact, this is a second button, the first one i thought was faulty and they kindly replaced it with this one and it still doesn't work.
Thanks in advance.
Not something that’s needed in my employee capacity, as we install authentic displays , so couldn’t tell you.
Gut feeling is nothing too difficult if your familiar with the inside of a iPhone
:) OK thank you for your advice, I'll check it out.
