iPhone Camera Problem
27 Sep 2004
The Ledge Beyond The Edge
I have a problem with my camera. Whenever i take pictures with it, it appears to put them in the film roll. But when i go to the roll, it looks like just blank squares. i go to open them, get a blank screen. Then when i exit the camera and go back into it, it says the roll is empty :confused:
It is jailbroken on 1.1.4.
I had a similar problem when I was playing around with the photo folder on my iPhone.
SSH into your iPhone, navigate to /Private/Var/Mobile/Media/DCIM and delete the 100APPLE folder.
Then try take a photo again and see what happens.
I had this problem and I think I just deleted the DCIM folder in /Private/Var/Mobile/Media/
After that it worked perfectly, the next time I took a pic it re-created the DCIM folder with the correct permissions.
