The Incase Rubber scratches the metal bezel (over time).
I guess it's the lip/edge of the rubber that micro-moves over the bezel and causes little scratches.
Do a Google, or search Mac Rumors and you'll find many threads. It is a good case, but once you put it on you'd have to keep it on, which is why I gave mine away.
Tbh, if i got a scratch on the back or bezel, it would annoy me, but then i'd live with it.
But any on the screen....![]()
In fairness you do find a reason to change nearly every single bit of your Apple related kit within three months of buying it![]()
I don't plan on taking it offi got a touch anyway, dunno how much difference that makes.
Why would you try?Scratch the screen? I've tried and failed! Would require a real gouge!
