Followed half of Justin's guide on unlocking my iPhone but can't get the 1.1.2 update (as only 1.1.3 is available via iTunes) to complete step 3 are there any other avenues to get the update?
If you are on a non 02 contract or other network and have updated to 1.1.3 in itunes then you may be stuck there!
If your phone had 3.9 bootloader on it you will be able to do the hardware hack to downgrade the bootloader, looking at your pic you have anysim installed so i'm guessing it did have 3.9 on it
I managed to go from 1.13 back to 1.1.2, but I didnt upgrade to 1.1.3 via iTunes, that is where your problem lies mate.
I had o start from the begining, putting 1.1.1 back on then jailbrake, upgrade to 1.1.2 then jailbrake. Give that a go, I had to reinstall iTunes as it was giving all kinds of the wrong error messages.
I had to start from the begining, putting 1.1.1 back on then jailbrake, upgrade to 1.1.2 then jailbrake. Give that a go, I had to reinstall iTunes as it was giving all kinds of the wrong error messages.
