- 1 Mar 2010
I have been looking to replace an old and damaged 24" BenQ and for first time I did a little bit of reading on the subject. Very briefly I learned there are 3 types of panels, TN for best latency but worst viewing angles and colours, VA for best colours, blacks, contrast but with "black crush" problems which literally every reviewer is quick to point out, and IPS as the kings of panels usually costing more, with extra wide angles and adequate latencies.
However after reading so many reviews which consistently bring up the "black crush problem" that plague the VA panels, I believe that there may be a bit of brainwashing going on.
I got a Dell U2412M from a friend who wants to sell it to me second hand and I set it up and ran some tests. It is a 1980x1200 IPS screen. It is perfect in every way except if you have a black background. First of all it is not black, it is a kind of silvery grey. Most importantly as you are looking dead centre head on, there is a glow that comes in from both sides of the screen and towards the centre. Move your head one or two inches up and the glow gets bigger, occupying a larger area of the screen. Move a bit to the sides and the glow gets less on one side and more on the other side. It is as if someone is shining a torch onto the screen from somewhere far. I am not talking about white bleeding here which this particular Dell did not suffer at all from.
In other words on an IPS panel (most made by LG by the way) there is no black colour and there is a ridiculous glow which is extremely distracting. Now, if I were reviewing an IPS panel I would say "do not even bother testing a black screen and do not even bother examining viewing angles on a black screen, it is a joke". But guess what, I have not yet seen such a review.
But when I read reviews about VA panels they consistently bring up the problem of the "black crush" which apparently is looking at a black screen with very dark objects/writing on it and if you are looking head on those very faint objects will not show until you move a bit off the centre. I have not yet examined a VA screen close, but it appears to me that I'd much rather that "problem" than not having a black screen at all, ever, and having a glare and a glow in my face.
So I am asking here owners of VA screens, in particular the BenQ GW2450 or GW2750 series - how bad is the "black crush" problem really? Could you please describe it to me so I may be able to compare it with the IPS problems?
Many thanks
Many thanks
